587,066 active members*
3,520 visitors online*
IndustryArena Forum > CNC Electronics > Xylotex > Quesiton on steps? This cannot be true is it?
Results 1 to 7 of 7
    Mar 2005
    215
    With a direct drive motor to lead screw, how many steps are you guy getting for 1 revolution when using Full, 1/4, Half, and 1/8 modes with the xylotex.
    After reading there documentation on the 4 axis board it seems that in Full step mode the driver will move the motor shaft 45 degrees for every input pulse. Is this true?
    AC
    Jul 2003
    1754
    You need to know how many steps per rev your steppers are. Most common ones are 200 steps per rev. So full stepping gives you that - 200 steps or 1.8deg per step.
    So half stepping would be 400 steps per rev. 1/8 stepping would be 1600 steps per rev.
    sam
    Mar 2005
    215
    Thats what I thought but the way the manual's step table looked it make it look like a 45 degree rotation in full step mode.
    AC
    Jan 2007
    64
    Quote Originally Posted by Alex_Cole View Post
    AC
    Those are electrical degrees, not mechanical degrees. When you go through 90 electrical degrees, I think you have taken one full step, or two half steps.
    Jun 2003
    3312
    Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
    Vist my websites - http://pminmo.com & http://millpcbs.com
    Mar 2005
    215
    Thanks guys that put the puzzle pieces together for me.
    AC
    Jan 2007
    634
    Actually, its pretty easy to understand. You see, each step is 45 degrees BEFORE taxes, Federal surcharge, dealer prep, and destination fees. You just get left with only 1.8 degrees when you are done. Just like real life. Simple, no?
  1. Pro/E, Too good to be true?
    By agewon in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-12-2007, 08:19 PM
  2. the true test
    By dertsap in forum DIY CNC Router Table Machines
    Last Post: 06-08-2006, 04:15 AM
  3. Full Steps -vs- Micro Steps
    By DJB282000 in forum CNC Machine Related Electronics
    Last Post: 12-29-2005, 06:25 AM
  4. Amazing (to me) if true
    By Chunky in forum Linear and Rotary Motion
    Last Post: 07-11-2005, 07:36 PM
  5. Too Good To Be True?
    By boss1 in forum OneCNC
    Last Post: 08-01-2003, 06:55 AM
