586,685 active members*
2,847 visitors online*
Results 1 to 4 of 4
    Oct 2014
    33
    Dyna 2400 100 tooth Gears
    I crashed my Dyna 2400 today and broke the Z axis 100 tooth gear. Has anybody done a retro fit and have a couple spares they would give up? PM if you do.
    Nov 2012
    367
    Re: Dyna 2400 100 tooth Gears
    I don't have a DM2400, but there are a gazillion retrofits out there if you poke around the web a bit. I think I even saw some turnkey kits, although I don't know why you'd spend that money. It looks like it would be a pretty easy machine to roll your own. The steppers are pretty low power, so drives should be easy.
    Oct 2014
    33
    I have looked at the retro's and have asked some of the people that have done them, about the motor mount. I'm wondering if they have made a plate to attach to the existing motor and electronics mount or if they have made a completely new one. I am almost at the point of no return on this project and wonder if the money should be spent on a newer manual mill and forget the Dyna. If I have to spend a few hundred more on mounts, couplers, and motors, and still have an undersized mill, I don't think its worth it. Even if I put 90 OZ 17's on it I would be tripling the power but the work envelope is still toy sized.
    Nov 2012
    367
    Sadly, I can't answer that one. Larger machines definitely have increase capabilities. But, they also require, well, more space! That is often a premium for hobbyists. I know that it is a constant "negotiation" between my wife and me, for instance.
    I've got a 4000lbs CNC in my garage. I'm tempted to call it full size, but the reality is that it is a smaller CNC. But it is still definitely in the professional landscape. I haven't regretted it.
    I have a brother that would love your DM2400 if you decide to dump it and aren't too far from me.
  1. Dyna 2400 motor mounts and Dyna 2800 spare parts
    By Grifftek in forum Dyna Mechtronics
    Last Post: 02-02-2020, 05:31 PM
  2. calculating tooth thickness in spur gears
    By coykiesaol in forum Mechanical Calculations/Engineering Design
    Last Post: 11-02-2010, 04:08 PM
  3. Dyna 2400
    By spin stack in forum Knee Vertical Mills
    Last Post: 02-25-2008, 04:52 PM
  4. Hardinge HLV-H Lathe, change gears, 127 tooth
    By leeputman in forum Uncategorised MetalWorking Machines
    Last Post: 01-18-2008, 02:29 PM
