586,761 active members*
8,124 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Crazy Y Axis drift when upgrading to Mach3
Results 1 to 5 of 5
    Hi, About 6 months ago i bought a 3040 from our chinese friends and upgraded it to a 2.2KW spindle. I have had relative sucess cutting aluminium on a laptop and parallel port to USB program USBCNC. It was cutting very accurately and with little issues apart from it would very intermittantly stop, Crash and reset its zero and scrap the part.
    After 10 or so parts scrapped over the months i decided to do away and get a proper dedicated XP desktop computer. I watched many youtube videos and set up mach3, taking care to correctly calibrate the steps per MM and set up soft limits. (Please note i didnt touch the actual CNC during the upgrade)
    I thought i had it sorted but there is a problem milling at multiple depths , and it appears the Y axis moves slightly negative each time it moves down a layer creating a step effect instead of a perfectly straight vertical cut, this even applys on old Gcode that came out perfect previously. All other axis work perfectly. Ive also tried .
    Ive thoroughly checked everything on the hardware side and nothing seems loose and the spindle is straight. Redone the step calibration for the Y axis multple times and it always is spot on with accuracy.
    Someone pointed out it may be a driver error, but surely that would cause the accuracy to be off when calibrating? Also im guessing (possibly wrongly) that this isnt a cnc problem, more of a computer problem as thats the only thing thats changed?
    Any help with this would be greatly appreciated as this really has me stumped.
    May 2003
    323
    Re: Crazy Y Axis drift when upgrading to Mach3
    Check for short on y axis wires I had mine crash and stop randomly . fixed it and no more issues.
    Sent from my MHA-L29 using Tapatalk
    Quote Originally Posted by ChrisW View Post
    That would perhaps explain the issue on my old set up but surely a short would cause the step unit calibration to be off?
    May 2003
    323
    It could lose steps whenever there's short and still keep going.
    Aug 2009
    1573
    try a new Endmill cutter
  1. Z Axis Drift......
    By bbristow in forum DIY CNC Router Table Machines
    Last Post: 02-22-2016, 11:10 PM
  2. Axis Drift, Need Help
    By Evanrigs in forum Uncategorised CAM Discussion
    Last Post: 05-07-2014, 07:53 PM
  3. Axis Drift HELP!
    By ppollioni in forum Open Source CNC Machine Designs
    Last Post: 04-22-2012, 02:35 PM
  4. Y axis drift
    By japco43 in forum Controller & Computer Solutions
    Last Post: 02-23-2011, 09:01 PM
  5. Z axis drift
    By IainLGrant in forum Benchtop Machines
    Last Post: 03-12-2006, 02:56 PM
