Hi, I am trying to machine a part using a hole machining cycle. I have 4 holes that are drilled .125" and I am using them with pins to locate the part on a fixture. What I am trying to do is use a hole machining cycle with a .155" end mill to machine the holes to .187". What it does is give me this message (MSG, Cycle doesn't supported) when I post the part. I am using SC 11.
Art
