587,080 active members*
3,072 visitors online*
IndustryArena Forum > Other Machines > Engraving Machines > Engraving Plastic Sign Material
Results 1 to 12 of 12
    Apr 2007
    67
    I just had my first go at engraving some dual layer sign material, not sure of it's technical name.
    I'm very new to cnc so I'm learning as I go.
    First I should mention it was trialled on a cnc router, using a 30deg. conical engraving bit with a flat 0.1 end. The router I used has a minimum speed of 11,500 rpm. unloaded. Feed Rate was around 600 mm/min.
    Anyhow as expected it was flop. The plastic quickly melted onto the cutting tip.
    I couldn't slow the router any more so I tried a water/detergent spray on to the cutter to help cool it down, but also without success.
    Can anyone offer some tips on engraving this type of material, or a link to a good source of relevant info.
    Thanks.
    Apr 2007
    7
    engraving plastic
    that type of plastic these using
    Dec 2006
    532
    what about tring to use faster speed(mm/min)?
    Feb 2007
    Your feed rate is too slow. That's a good way to start a fire. Typically you need a tooth load greater than 0.001" (0.025mm) per tooth per revolution. Try feeding in the 2000 to 3000mm/min range. Slow down to improve finish or prevent breaking small diameter cutters.
    Apr 2007
    67
    At the moment the old girl won't do 2000mm/min feeds.
    I'm upgrading to a coarser pitch ballscrew to improve speed and accuracy.
    I'm also going to try another brand of router that has a minimum speed of 8000 rpm. which might help as well.
    All part of the learning process I guess.
    Jul 2007
    41
    can it be engraved by a laser engraving machine??
    Apr 2007
    67
    Yes it probably could be done with a laser, but I have a rotary machine.
    I built myself a multi-purpose machine and was hoping to be able to some engraving on plastics and other materials.
    It was my first effort, so it now needs some refinement of technique and machine.
    Feb 2007
    71
    maybe get a variable speed controller for your machine? run the motor at maximum and then use the variable speed control to slow it down, might work to get your rpms down.
    Ive got some plastic on order, and cant wait to try it out.. now Im worried about melting!
    (crossed fingers)
    ~Steve
    Jul 2007
    8
    I think thename of the plastic is Traffilite and when ordering you specify black white black or whatever colour preferencies you require
    Nov 2003
    244
    Actually it is a co-extruded plastic for engraving. Traffilite might be a brand name.
    http://www.artisan-es.com/Rowmark.htm
    Tom
    ...He who makes no mistakes makes nothing! ...
    Tom
    Jul 2007
    8
    I Stand Corrected, Traffolite Is A Tradename Abit Like Delrin And Acetal
    Nov 2003
    244
    There is a plastic designed for laser different from engraving type also here is a link addressing your problem.
    http://www.talkshopbot.com/forum/mes...tml?1180131665
    Tom
  1. I need suggestions for outdoor sign material.
    By Glidergider in forum Glass, Plastic and Stone
    Last Post: 05-21-2009, 02:15 AM
  2. 2 ply engraving plastic?
    By DennisCNC in forum Engraving Machines
    Last Post: 05-08-2007, 12:37 AM
  3. high performance plastic - bearing material
    By Chris D in forum Glass, Plastic and Stone
    Last Post: 09-03-2005, 12:43 PM
  4. Plastic Sign Material - Where to purchase?
    By edbo68 in forum DIY CNC Router Table Machines
    Last Post: 04-27-2005, 04:59 AM
