586,536 active members*
2,771 visitors online*
    Mar 2007
    60
    Calculating steps per revolution
    I just wanted to verify my steps per unit. I calculated 8000.
    My calculation is based on the motors being 1.8 deg. or 200 steps per rev.
    I have Nema 23 steppers at 495oz. Using Keling 4030 drivers set at 1/8 microstep.
    Mechanical Drive - 1/2 10tpi 2 start screws ( I calculated .2 thread pitch so 5 revs per unit)
    Here's my formula:
    200 x 5 = 1000 then 1000 revs per unit x 8 (for 1/8 microsteps) = 8000
    or
    200 x 8(microsteps) = 1600 then 1600 x 5(turns per unit) = 8000
    Does this sound correct?
    Aug 2004
    3215
    Yes that is correct.
  1. Need help on calculating steps
    By rustamd in forum Mach Software (ArtSoft software)
    Last Post: 08-03-2007, 01:08 PM
  2. Help calculating power please?
    By Oldmanandhistoy in forum CNC Machine Related Electronics
    Last Post: 05-30-2007, 04:00 PM
  3. Full Steps -vs- Micro Steps
    By DJB282000 in forum CNC Machine Related Electronics
    Last Post: 12-29-2005, 06:25 AM
  4. calculating inductance
    By 2muchstuff in forum CNC Machine Related Electronics
    Last Post: 11-13-2005, 07:27 PM
  5. Calculating "steps per unit" for rotary axis?
    By Beezer in forum Mach Software (ArtSoft software)
    Last Post: 11-28-2004, 10:31 PM
