586,892 active members*
4,248 visitors online*
IndustryArena Forum > CAM Software > Surfcam > Inverse Time feed rates
    Jan 2012
    97
    Hi does anyone have an example of a post file S or M, that is using inverse time feed rates for a Haas 4th axis programming..?
    Thanks in advance...
    Hi machinster, talking of a Haas machine; input the correct diameter of the part to be machined in the Setting #34, and then all you have to program is something like this:
    G01 X2.500 Y0 A131.523 F5.1
    Knowing the diameter of the part, the control will interpolate both axis to reach the end of the move at the specified rate.
    Here is a partial Haas post that I used for years.
    name Haas 4 axis VF2 (Metric) ( BY Mario Lovato 15/04/1997 )
    % 00
    / 00
    O >4
    N >4
    A ->4.>3 Limit -8000 8000
    I ->4.>3
    J ->4.>3
    K ->4.>3
    ModalLetters X Y Z F A # List of letters that are modal
    ModalGs 0 1 2 3 73 74 76 80 81 82 83 84 85 # List of g codes that are modal
    StartCode
    %<0>
    O<Program#>
    G<80> G<49> G<40>
    G<28> g<91> Z<0>
    G<28> g<91> Y<0> A<0>
    End
    1stToolChange # First tool change
    T<Tool> M<6>
    G<0> G<90> G<17> G<Work> X<H> Y<V> A<Rotangle>
    G<43> Z<D> H<Lcomp>
    M<Direct> S<Speed>
    M<Cool>
    End
    Infeed # Enable cutter comp
    G<Side> X<H> Y<V> D<DComp> A<Rotangle> F<FRate>
    end
    Outfeed # Disable cutter comp
    G<1> G<40> X<H> Y<V>
    Z<D>
    end
    EndCode
    M<05>
    M<09> # End of the program
    G<0> G<49> G<90> Z<0>
    G<28> g<91> Z<0>
    M<02>
    M<30>
    %<0>
    End
    Index X # Index the rotary table
    G<43> Z<D> H<Lcomp> M<Cool>
    End
    UnWind # Unwind the rotary table
    A<0>
    G<0> X<LastH> Y<LastV> A<LastRotAng>
    G<1> Z<LastD>
    End
    Should you need more info, just call me.
    Good Luck.
    Mario
    Re: Inverse Time feed rates
    A week ago I posted a probable solution, just in case you didn-t see it.
  1. 4th axis inverse time feed rates
    By hotiron in forum Fanuc
    Last Post: 10-22-2015, 01:24 PM
  2. older yang mill doesnt like g93 inverse time feed
    By turboprogrammer in forum Fanuc
    Last Post: 06-26-2015, 01:06 PM
  3. (5 Axis) proper inverse time feed in BobCAM Post?
    By CWILLIS1477 in forum BobCad-Cam
    Last Post: 06-23-2015, 04:01 PM
  4. 4 and 5 axis post question (inverse time feed)
    By pinguS in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 11-22-2013, 12:46 AM
  5. G93 Inverse Time Feed Mode
    By MarkT in forum Haas Mills
    Last Post: 01-18-2007, 07:28 PM
