586,655 active members*
4,687 visitors online*
    Feb 2014
    197
    Raising the dead
    I have a G0704 that I converted using Hoss's plans and one point suggestions on stepper/driver setup. I'm in the process of taking the electronics that I had for the mill and running them on a G0602. I have a few issues though. I may have damaged my C11 but I have not been able to validate that. The electronics were working with the G0704, but I inappropriately hooked up a C6 pulse card to the C11. Magic smoke was released from the C6 but nothing on the C11. I shut everything down and haven't bothered the project for about a year. At one point, since the last time the controller has been used successfully, I cleaned the computers drive and reinstalled Mach3. I essentially have a mess on my hands and just want to get this thing going. I think I have Mach3 communicating correctly with the ESS. I am getting no LED's on the C11 pin ports, but everything else looks lit and correct. I have 1V on ports 2-7 and 5V on the COM ports. I get no changes in voltage when I jog with the keyboard. The DRO incriments when I jog, and Andy at Warp9 says that means the ESS and the computer are talking. I'm about to wire in the C10 to see if it's the BOB but thought I would ask here first....maybe someone has some suggestions?
    Also, I can move the ball screw by hand.....so there's that too.
    Thank you.
    Items I have:
    -KL-5056D stepper drivers
    -570oz steppers
    -ESS
    -C10 BOB
    -C11 BOB that maybe damaged
    -BD Tools G0602 CNC kit
    Nov 2009
    4415
    Re: Raising the dead
    You can move the ballscrew by hand, stepper attached and powered up? That shouldnt be the case.
    A lazy man does it twice.
  1. Help with my Z raising during 3d carving
    By KurtRosenzweig in forum Chinese Machines
    Last Post: 06-14-2018, 03:46 PM
  2. Series 1 BOSS 5 X Axis Dead, still dead after new transistors
    By keebler303 in forum Bridgeport / Hardinge Mills
    Last Post: 02-01-2014, 04:27 PM
  3. Mazak M5 DEAD BATTERY -DEAD CONTROL
    By tired_iron57 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-06-2012, 07:35 PM
  4. Fanuc 0 dead screen ... dead control?
    By Noss Machine in forum Fanuc
    Last Post: 01-24-2009, 04:03 PM
  5. Raising Voltage from 12 to 24v
    By Marcvw79 in forum Hobbycnc (Products)
    Last Post: 03-11-2008, 11:29 PM
