586,540 active members*
3,001 visitors online*
    Jan 2018
    9
    PM940 5 axis build
    I am working on a 5 axis PM940 based around a 12" bridgeport rotary table for the c axis and some wheel hub bearings for the a axis. The large Z travel of the 940 and wide table makes this setup feasible. I am using fusion 360 and linuxcnc. I am wondering whether linuxcnc kinematics support dynamic work offset. Still reading through the code. I've made a vr180 video of the hardware so far and am curious about your thoughts:
    Dec 2019
    I watched your video. are successful
    Jan 2018
    9
    Re: PM940 5 axis build
    Still working on this, new panel. New dual worm drives for the A axis, zero backlash. Currently working on a new PM940 input shaft for a bluemax 1hp motor. I also received two more PM940's to convert to regular 3 axis CNC. Using linuxcnc for everything
  1. Precision Matthews PM940 CNC mill and 1030 lathe
    By Pariel in forum For Sale Only
    Last Post: 03-10-2019, 09:36 PM
  2. Precision Matthews PM940 CNC mill
    Last Post: 10-28-2018, 01:48 PM
  3. My DIY power drawbar for the PM940 CNC VS No air needed
    By rodjava in forum Benchtop Machines
    Last Post: 11-20-2017, 02:49 PM
  4. CNC build using more than 5 axis
    By PD Woodcraft in forum Mach Software (ArtSoft software)
    Last Post: 03-19-2016, 08:24 AM
  5. 4th axis build
    By contactirfu in forum DIY CNC Router Table Machines
    Last Post: 11-04-2009, 04:50 AM
