586,847 active members*
2,414 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > PCNC 1100 spindle control with Mach4 & ESS
Results 1 to 10 of 10
    May 2011
    18
    Question PCNC 1100 spindle control with Mach4 & ESS
    Hi All, I recently inherited a PCNC 1100. My brother had used the machine with Mach 3 and ESS. The PC he used to run the machine crashed, and we replaced it, but due to failing health he had not been able set up everything.
    I have upgraded it to Mach4 with ESS and have everything working except the spindle speed control. I am using Step and Direction for spindle control... If anyone is using a similar set up, could you give me some tips on how to adjust the spindle speed from mach?
    Thanks in advance,
    Andy
    Apr 2008
    19
    Re: PCNC 1100 spindle control with Mach4 & ESS
    Recommend that you upgrade to Pathpilot. https://www.tormach.com/store/index....show&ref=38710
    May 2011
    18
    Thanks for the suggestion but really looking for an answer, not a recommendation. The machine originally ran Tormachs version of Mach 3, it was converted to regular Mach 3 in order to incorporate the ESS. I currently have Mach4 and am very happy with it on two other machines I have and want to use it on this machine to keep everything the same.
    Andy
    Jun 2014
    1780
    Quote Originally Posted by andysims View Post
    Andy
    Maybe try a Mach forum? I havent seen any Mach 4 users posting on the Tormach forum since the inception of Pathpilot.
    mike sr
    Apr 2016
    841
    You could go to the Mach support forum. There is also the Warp9 forum (smoothstepper). The folks at Warp9 provide direct support (unlike for Mach4 Hobby) and go above and beyond trying to help. There is also a forum here for Mach4. If you are using a VFD, there is a forum here on the Zone dedicated to VFD/Spindle combinations with some very knowledgeable folks.
    The problem is that you are in a narrow forum with users who aren't likely to relate to your issue. Yours appears to be a software setup issue (ESS, Mach4 or both, or maybe something to do with a VFD), assuming you have your hardware all hooked up correctly.
    I wish I could be of more help, but I have a wood router CNC with spindle & VFD, and use PMW (0-10V) to control my spindle speed. All I have to offer is to point you in a better direction to get the answer you need.
    May 2011
    18
    Hi GME, Thanks for your reply... I have posted on both Warp9's and Mach's forums.and like you said Warp9 has responded but no one from Mach. The problem is a setup issue, I have mach4 controlling the spindle but calibrating the speed control is where I'm hung up... I too have a wood router CNC using Mach4 with VFD and have a 3D printer we built from scratch that uses Mach4, so I have a pretty good knowledge of Mach4 set up... just not familiar with the Tormach stuff. Again thanks for responding.
    Andy
    Nov 2007
    2151
    Andy
    This might help
    Could not copy text so I pasted pictures of old manual. I don't know if this is still available from tormach um10087 pcnc manual pdf
    Attachment 433320
    Attachment 433322
    May 2011
    18
    Thanks MountainDew... I had just found those documents today and was making some adjustments based on some of the information they contain. I have made a lot of progress today and will post some info soon that may help others with similar setups.
    Andy
    Mar 2009
    1863
    Andy
    I have I had my PCNC 1100 Series II since July 2011 and I’m still running Mach III and it’s running flawlessly.
    For a while I thought about switching to Path Pilot but I’ve read about too many things my Mach III will do that Path Pilot won’t. Things like tap holes.
    You can probably use Steve's Mach 3 settings to setup Mach 4.
  1. Spindle Error (PCNC 1100 Series 3)
    By Eli_Ben in forum Tormach Personal CNC Mill
    Last Post: 02-22-2020, 07:40 PM
  2. PCNC 1100 spindle speed display
    By Chincia in forum Tormach Personal CNC Mill
    Last Post: 05-05-2018, 06:56 PM
  3. PCNC 1100 Spindle bolts
    By MFchief in forum Tormach Personal CNC Mill
    Last Post: 01-19-2017, 08:28 PM
  4. Move control cabinet outside of enclosure PCNC 1100
    By Strip in forum Tormach Personal CNC Mill
    Last Post: 02-24-2016, 11:26 PM
  5. PCNC 770 or 1100 Spindle Motor Specs?
    By techsavvy34 in forum Tormach Personal CNC Mill
    Last Post: 03-17-2015, 08:43 AM
