586,698 active members*
2,994 visitors online*
    Dec 2019
    UC400ETH and MACH3 connection problem solution
    Hi
    I had some problems to get the UC400ETH to connect in mach3, (displaying blue light on the unit).
    A lot of google time did not help me, but the solution was actually hinting me. Mach3 is giving information about firmware update, but I was receiving error when I tried to update.
    The solution is to make sure that you select all UC400ETH plugins in Mach3 plugin configuration.
    Jun 2015
    943
    Re: UC400ETH and MACH3 connection problem solution
    Quote Originally Posted by mr_firebladeswe View Post
    Hi
    You should have only one UC400ETH plugin in the Mach3 folder. If you have more than one that is a problem.
