586,682 active members*
2,530 visitors online*
    Jan 2013
    15
    VF3 power failure alarm
    I am getting a power failure alarm a few times a day on my 1994 VF3. The control freezes up and I have to cycle the power to clear. No alarm code is given, just the words 'power failure alarm' as you can see in the image attached. Has anyone had a similar problem and found the source of the problem?
    Jordan.
    Nov 2007
    479
    Re: VF3 power failure alarm
    I would google Haas Australia and call the closet hfo near you and talk with tech support.
    Quote Originally Posted by agsy103 View Post
    Jordan.
    Did you end up fixing this if so what was the problem?
    Ron
    Jan 2013
    15
    Quote Originally Posted by RnjPrecisionLLC View Post
    Ron
    No, it just went away. It usually only happens on hot days. I believe there are some diodes on the powerboard that wear out.
  1. Fanuc Power Failure Backup Module Alarm 0.(Dot)
    By jjautomation in forum Fanuc
    Last Post: 10-22-2019, 05:48 PM
  2. 1-1 cpu-alarm bus failure (cycle out)
    By piston_90 in forum Okuma
    Last Post: 11-15-2017, 03:42 PM
  3. 198 Alarm (Precharge Failure) TSC Not Working
    By Eric MFG in forum Haas Mills
    Last Post: 11-01-2015, 10:04 PM
  4. Help -- what to do in power failure?
    By robedney in forum DIY CNC Router Table Machines
    Last Post: 04-20-2013, 06:48 AM
  5. ATC TURRET FAILURE and ALARM
    By scadvice in forum Fadal
    Last Post: 03-29-2011, 05:36 AM
