586,610 active members*
3,659 visitors online*
IndustryArena Forum > CAM Software > MadCAM > Project Curves?
Results 1 to 6 of 6
    Mar 2014
    6
    Project Curves?
    I don't know how to make this work.
    I want to flow a curve along the surface of the model, just a profile curve. There doesn't seem to be a way to specify the depth of the cut. Only "Stock To Leave."
    If I set it to a positive number, the toolpath is above the model.
    If I set it to 0, the toolpath is on the surface of the model.
    If I set it to a negative number, the toolpath is below the bottom of the model.
    If I want to cut along the curve, onto the surface of the model 0.020. how do I do that?
    Mar 2004
    1661
    Re: Project Curves?
    Sorry, I don't understand, isn't -0.020 what you are looking for?
    Alternatively lower the curve where you want it. If it is a 3D surface project the curve onto the surface, make an offset downwards 0.020 and use the new curve.
    Mar 2014
    6
    Re: Project Curves?
    I want -0.020 relative to the top surface.
    I get -0.020 down below the BOTTOM surface.
    Yes, I can force the same results a different way, but it seems others get this function to work.
    Mar 2004
    1661
    Re: Project Curves?
    I did an irregular box and used MadCam's Project Curve feature, please note that the projected curve is above the entire model. This is a tool path with a 5 mm ball mill with -2 mm Stock to Leave. Is this what you are looking for?
    Mar 2014
    6
    Re: Project Curves?
    Yes. That is what I am trying to do.
    When I use negative stock to leave, the toolpaths generate below the bottom of the model. Below z-zero, not below the top of the model.
    Mar 2004
    1661
    Re: Project Curves?
    There is only one way you can cause the toolpath to hit the bottom, and that is if you set a greater Stock to Leave than half the cutter diameter. It is a known habit and the reason is that the the cutter will "plunge" through the top surface during the calculation of the tip position, it is simply a mathematical issue.
    There are two ways around the problem. Either use a larger cutter when you generate the tool path, it doesn't matter if you double the size as it is a Z-level operation only. Or, you can create a toolpath with Stock to Leave set to zero and then move the path where you want it.
    If the depth is important (like in projected depth on a non linear surface), you should instead project the curve on to the surface with Rhino project commands and make an offset curve. Then, you can use MadCam's Along Curve instead on the new curve.
  1. Project Curves for Engraving and More!
    By aldepoalo in forum BobCad-Cam
    Last Post: 02-26-2016, 07:00 PM
  2. Project Curves Engraving Problem in Simulator
    By trelos_zoi in forum MadCAM
    Last Post: 12-22-2015, 08:53 PM
  3. RPM vs. HP Curves
    By velocityxlrg in forum Tormach Personal CNC Mill
    Last Post: 05-30-2013, 02:43 PM
  4. Replies: 1
    Last Post: 11-08-2011, 05:30 PM
  5. Help with Curves!
    By Chris64 in forum SheetCam
    Last Post: 08-31-2007, 07:31 PM
