586,799 active members*
2,922 visitors online*
IndustryArena Forum > MetalWorking Machines > OKK > OKK VP400 5 AXIS Z AXIS OFFSET ERROR WHEN MACHINE TURN A AND C AXIS
    Jun 2019
    Red face OKK VP400 5 AXIS Z AXIS OFFSET ERROR WHEN MACHINE TURN A AND C AXIS
    HELLO
    TO ALL
    I HAVE A PROBLEM IN THE MACHINING OF THE ROTARY AXLES OF AN OKK VP400 THE G54 IS ABOUT THE MASTER PART WITH THE A Y C AXES IN ZRN EXACTLY AT 0.026 THOUSANDS UP FROM THIS WHEN A MEASURE VERIFICATION IS CARRIED OUT IN THE FOUR FACES OF THE MASTER BLOCK MESURES AS FOLLOW :
    SIDE 1 MEASURE 0.024 "
    SIDE 2 MEASURE 0.030 "PLACED BELOW SIDE 1
    SIDE 3 MEASURE 0.018 "
    SIDE 4 MEASURE 0.033 "
    THE MEASURES ARE ALWAYS PERFORMED WITH THE PART ORIENTED PLANE XY
    I TRY TO MOVE THE PARAMETERS OF FANUC 19700,19701, 19702 AND NO CHANGES ARE ALREADY REMAINED. (THE PARAMETER CHANGES BUT THERE IS NO CHANGES PHYSICALLY)
    THE GEOMETRY OF THE AXES A AND HAVE BEEN VERIFIED ITS PLANNING IS BELOW 0.010mm 0° AND 90°
    I hope someone has information on how to enable the compensation of axes A and C OR WHY Z AXIS IS COMPENSATE IN THIS WAY I WILL APPRECIATE THE HELP
    THANKS IN ADVANCE
    Jan 2024
    Re: OKK VP400 5 AXIS Z AXIS OFFSET ERROR WHEN MACHINE TURN A AND C AXIS
    Hello,
    I have the same problem, did you manage to solve it? I was looking for too much information but I can't solve it
  1. Can’t turn on axis (after turn off machine during G-code)
    By RuslanRobot in forum Dynomotion/Kflop/Kanalog
    Last Post: 07-09-2019, 08:48 PM
  2. Replies: 2
    Last Post: 11-22-2016, 06:51 PM
  3. Replies: 3
    Last Post: 09-03-2015, 04:01 PM
  4. Replies: 0
    Last Post: 08-04-2013, 05:30 AM
