586,551 active members*
3,246 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Okuma RU1 board relays
Results 1 to 7 of 7
    Jan 2011
    16
    My LB15 won't unclamp the chuck. We have it narrowed down to the RU1 board. Can somebody please tell me which relays on the RU1 board need to be replaced when the board fails? Any help will be appreciated. Thanks.
    Jan 2009
    55
    Re: Okuma RU1 board relays
    Quote Originally Posted by Farmer Machine View Post
    On my Cadet lathe, I changed CROKA and CRVAC relays. They are both Omron LY2N 24vdc relays.
    Feb 2009
    6028
    You must have an odd Cadet, all I saw had the RU1 board as well, and they are solder on.
    I can't seem to find my Cadet electrical prints right now, only the OLD LB15. I'll keep looking, they are labeled on the prints.
    Jan 2020
    Same problem on our cadet. Both sides of the solenoid is magnitized, So we found a used board. But I will see if replacing those relays fix our bad board. Thanks for the post
    Jan 2014
    Did you have any luck replacing the relays on your board.
    Also any guidance on finding the RU1 board, have a 199 Okuma Crown L1060. giving me Alarm 1725-A CHUCK ls-sol mismatch
    Oct 2010
    25
    may be it is to late by the way I am Attaching a small picture of the chuck clamp unclamp diagram located on RU1 You need to define which relay need to be changed
    Oct 2010
    25
    some info I hope ththis help
    Attached Thumbnails Attached Thumbnails U10 CONTROL FUB-P4M4 CROWN.jpg   FUB-P4M4 EQUIVALENT TO RU1 .jpg   RU1 CADET LNC8.jpg
  1. Replies: 2
    Last Post: 05-18-2019, 08:52 PM
  2. C23 board relays
    By Sweeney in forum CNC4PC
    Last Post: 03-24-2016, 01:37 AM
  3. Okuma Howa ACT 20 Keep relays,timers,Help
    By cdn farmer in forum Okuma
    Last Post: 09-21-2012, 09:53 AM
  4. Okuma Howa 630H keep relays
    By banshee1a in forum Okuma
    Last Post: 11-05-2008, 04:03 AM
  5. Breakout board, Relays on board?
    By Cooper in forum Open Source Controller Boards
    Last Post: 06-10-2007, 01:55 AM
