586,670 active members*
3,206 visitors online*
IndustryArena Forum > MetalWorking Machines > Deckel, Maho, Aciera, Abene Mills > DMU 80T - manual tool change (horizontal spindle)
    Sep 2019
    Question DMU 80T - manual tool change (horizontal spindle)
    Hello!
    I have DMU80T / Heidenhain 430 / with integrated rotary table, manual adjustable head and automatic tool changer.
    Sometimes we change the tool manually when it's too long.
    I've met a problem with manual tool change with head rotated (for example to horizontal position).
    Each time machine tells me that I can't change the tool because it's not in vertical position to reach tool magazine.
    But when I want to change the tool manually it doesn't matter if it's horizontal...
    Anyway the only solution I found is to put head back into vertical position, then change the tool manually, then put it back to horizontal position... it takes a great time to do it sometimes...
    Generally working on horizontal spindle is annoying because of this problem.
    Anyone have the same problem, and any horizontal-fast-toolchange solution?
    Michael
    Apr 2014
    20
    hello dear
    i have a dmu 80t itnc 530
    machine i need electrical wiring diagram please help me
    email [email protected]
    Apr 2014
    20
    hello dear
