586,149 active members*
3,458 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Help With a Different Application for a Fanuc 21T
    Sep 2006
    31
    Hi All,
    I'm using a Fanuc 21T on a custom wire bending machine. The current configuration is using the C axis to feed the wire and the X axis to manipulate the bending mandrel.
    The program uses a G90 to set the initial position Of the X axis then switches to G91 to position the mandrel and feed the wire incrementally off of a large spool (production quantities range from 60 - 3000 pieces).
    The C axis position reads out in degrees ( 0-360 ) And the amount of wire fed is usually less than 360 degrees worth. Being in incremental mode, the start stop position is irrelevant as the counter can run past 360 and just start from where it stops.
    I have an application and want to run in absolute all the time. Is there a way to reset the C axis counter to zero after each cycle? If not, any suggestions on alternative solutions will be appreciated.
    Thanks.
    Dec 2005
    55
    Azden,
    You just need to look up the parameter number for for the C axis in the coordinate system you are using. Write a line in your code that says;
    #(whatever the number is)=0. and your C axis will be set to zero in your coordinate system.
    Jon K
    For the 18T it looks like the parameter number is #5223
    Sep 2006
    31
    Sump Cleaner,
    Thanks I'll look into that. I just came across a polar interpolation program that may work also. Know any tips or tricks?
    Thanks again.
  1. Best VMC for my application?
    By FTSCNC in forum Uncategorised MetalWorking Machines
    Last Post: 06-24-2008, 03:04 AM
  2. Servo Application
    By dyingbreed in forum Servo Motors / Drives
    Last Post: 05-26-2006, 07:55 AM
  3. What a great application!
    By wholepair in forum Machine Created Art
    Last Post: 03-23-2006, 12:29 PM
  4. Need Application Advice
    By slevy in forum Linear and Rotary Motion
    Last Post: 03-21-2006, 12:20 AM
  5. Help with a Stepper application?
    By Enzo in forum Stepper Motors / Drives
    Last Post: 08-22-2005, 12:30 PM
