586,761 active members*
7,500 visitors online*
Thread: 6040 upgrade
Results 1 to 7 of 7
    Jan 2007
    626
    6040 upgrade
    I know these machines have their limitations and I am not trying to fix them all.
    I am using it as a stepping stone until I am able to build a T Slot machine, down the road.
    My Router is the X61500GT, which has supported round rails for the Y axis and unsupported round rails for the X and Z axis's.
    Seeing as the Z axis rails are quite short, they should not have as big of effect on ridgity as the X axis would.....
    I was thinking that could quite easily replace the unsupported round rails with supported version and keep them in the same location.
    I would also fit a 12mm thick aluminim plate across the back of the gantry.
    I would have to pack the rails with 3mm spacer to get them back in the same spot but that is no biggie.
    I know I should use linear rails, but that would entail significantly more work to get everything to fit, and it still would not be a 'great' machine.
    My though is that this would be relative easy mod that would give me the most improvement in ridgidity.....
    Do you think it is worth the effort or will it be a waste of time and money?
    I've seen others mount a linear rail to the back of the X axis andjoin that to the top of the Z axis to reduce defection, but I am not sure if that is a better way to go.
    Pic is of the side view of the gantry.
    Steve
    Attachment 427144
    Feb 2009
    6028
    Re: 6040 upgrade
    Doing the same with mine eventually. I think it would help, if nothing else the bearing blocks have adjustment on them to take up any lash between the rails and bearings.
    1230
    Re: 6040 upgrade
    It has to be a substantial improvement over unsupported rails and isn't hugely expensive.In addition,if the ultimate plan is for a bigger and better machine,whether you make one or buy one,the existing machine will be a better prospect for selling on with evidence of an upgrade.It may help if you make a sample part before and after the change to demonstrate the improvement.
    Nov 2012
    1267
    Re: 6040 upgrade
    I don't think it would be a HUGE improvement, but with those machines you need every little bit of rigidity you can get. And the cost is not too steep, so I would go for it.
    Sep 2019
    197
    Re: 6040 upgrade
    I had one.....personally i would not do any upgrades when i was planning a new build.
    Jan 2007
    626
    Re: 6040 upgrade
    I now know why no-one has ever done this....
    It can't be done the way I was going to do it....I should have looked closer....Of course the Round LInear Guides are completely enclosed!
    I'm an idiot....lol
    Attachment 427244
    If I did this it would require a huge re-build and the result would not be worth the effort......
    Oh well....as you were lads...lol
    Steve
    I know you Erick...your just teasing me....lol
    Sep 2019
    197
    Re: 6040 upgrade
    Time to take the plunge mate, start your build??
  1. 6040 Router Upgrade
    By hive8 in forum Chinese Machines
    Last Post: 08-30-2022, 03:39 PM
  2. Upgrade 6040 to Gecko G540, what else do I need?
    By vosser in forum Chinese Machines
    Last Post: 08-31-2018, 06:01 PM
  3. CNC 6040 - upgrade to KFLOP
    By CNCtronic in forum Dynomotion/Kflop/Kanalog
    Last Post: 11-07-2017, 08:15 PM
  4. Planning to upgrade my 6040
    By DaMaDo in forum Chinese Machines
    Last Post: 10-26-2017, 08:53 PM
  5. Extend Z Axis upgrade on CNC 6040
    By rjmatseer in forum Chinese Machines
    Last Post: 07-31-2017, 09:04 AM
