586,983 active members*
4,086 visitors online*
Results 1 to 11 of 11
    May 2003
    792
    Arrow THK rail plugs
    I phoned THK about these little plastic plugs- here's the info if anyone needs it.
    These are called C-Caps and marked according to bolt size. Example:
    HSR15 rail- M4 bolt- C4 cap
    HSR20 rail- M5 bolt- C5 cap
    The prices are about $0.16 for C4 and $0.33 for C5 (per cap).
    Unfortunately, they don't sell them direct, not even from their online TOS store. When you go through dealer (like Technico):
    C4 cap $0.25
    C5 cap $0.50
    Jul 2006
    1256
    Finally a THK part I can afford without E-Bay.
    Larry
    L GALILEO THE EPOXY SURFACE PLATE IS FLAT
    May 2003
    792
    Here's the picture.
    _
    Jul 2006
    139
    Re: THK rail plugs
    Just an update to the thread. I pinged THK about plugs for my SHS15 rails. They need C4 plugs (4 for 4mm mount screws). They added them to the store for me (now $.025). Ordered up 62 for about $25 including shipping. So you can get them from THK direct now.
    Jul 2006
    139
    Re: THK rail plugs
    OK, so I got some of these plugs from THK. They are fairly hard plastic. A see no easy way to get them in the holes where they are not either a) too high or b) too low. Anyone have experience using them?
    Mar 2010
    11
    Re: THK rail plugs
    why don't you just hammer it in. it can't go deeper than the rail surface unless you are poking it in with something smaller than the cap.
    Jul 2006
    139
    Re: THK rail plugs
    Doesn't work like you think it would. Needs to be set around the edges slightly below because they basically push back some. A flush whack does not set them properly.
    Mar 2010
    11
    Re: THK rail plugs
    I see. well, maybe you can buy some other manufacture's caps. everyone makes them and the rail hole sizes are all the same. some european manufactures makes them in metal with rubber o-rings if you want to go nuts.
    Jul 2006
    139
    Re: THK rail plugs
    Where? Who else? I couldn't find anything different when I looked.
    Mar 2010
    11
    Re: THK rail plugs
    Bosch and Scheeberger both offers metal plugs. I assume most linear rail mounting holes are same size that you can use these on other manufactures rails too. I haven't done it personally so i can't guarantee anything.
    Guide Rails - Guide Rails - actuators, ball ballscrews, bearings, Bosch bosch, guides, leadscrews linear linear, motion, rexroth rexroth, screws, shafting, star star,
    Jul 2006
    139
    Re: THK rail plugs
    I have an account with Bosch, looked them up. Mine are 7.5mm (THK SVS15R), their smallest is 11mm. They use some sort of press to get theirs in.
  1. Questions on rail covers, dual servo hunting,and rail preload
    By Plugger in forum Uncategorised MetalWorking Machines
    Last Post: 05-14-2011, 05:00 AM
  2. Microphone DIN plugs
    By Apples in forum CNC Machine Related Electronics
    Last Post: 07-23-2010, 11:04 AM
  3. rail plugs
    By mechanicer in forum DIY CNC Router Table Machines
    Last Post: 01-23-2006, 07:12 PM
