586,544 active members*
3,048 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > Trumpf Trumatic 260Rotation - error message
    Sep 2019
    4
    Trumpf Trumatic 260Rotation - cannot find reference point
    Hello,
    recently we bought used Trumatic 260 Rotation. After assembling it normally found the reference point. Several times without any problem. However last week after starting of the reference point process the machine moved with the main table to the front and with X axes to the right. Then it stopped work.
    We manually pushed the X and Y approx. to the central position.
    Now when we press start for the reference point process it only moves with the punching head slightly up and down and nothing more. No error messages.
    No move either in X nor in Y direction.
    Any help with this old machine?
    Thanks for any suggestion.
    Ladislav
    Dec 2019
    Check your limit switch and be sure no clamp in dead area. Is a clamp is so close head the machine won’t move to avoid crashes
