hey antonismel, i remembered that you also posted this, a while ago :
https://www.cnczone.com/forums/okuma...l-tapping.html
so, there was a thing, you needed to exit and re-enter, you went on holiday on greek islands, and still, after a lot of party, you still need to exit and re-enter
funny, ha ?
about this, tea hole was spot on : "
You may have a small issue possible if you exit and re-enter a hole over and over again ... need to reconsider your process to tapping a hole "
so, what is actually going wrong ? why do you need to exit and re-enter ? i mean, even if you use g284, let's do it with g84, so to save time , etc ... are you using lower quality taps ? do you have a problem with chip evacuation, is the hole realy biiiiiig/deeeeeeep, what is it ?
you are so innocent
so, is like only an okuma machine needs to re-enter, not also a heidenhain; okuma is faulty, while on a heidenhain, so far, you never needed to re-enter / you got me
ohh, you are so kind : what about a group hug ? you hug tea-hole, i hug you, combinations
