I'm 100% clear on memory, lots available. When I'm transferring a file (not rally *that* large, 21kb), the file doesn't transfer all the way. Ive tried many different times, baud rates, flow control etc its NOT that and I've been transferring files to the machine for months, no issues. JUST this one file, it gets truncated. I've tried shortening the file, and can confirm "more" of it (the shortened version) goes through.
So is there some sort of file size limitation that I'm running into that I haven't seen before ? The total size of the file that does work is around 20377 bytes, and a version of the file that DOESNT work is same file with more lines, 20513 bytes on disk...
Thoughts ? Its not the command either, as I just filled the bottom with comments, they still dont go through.
