586,567 active members*
3,674 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Haas VF-2 RS-232 Cable Using a Switch
    Dec 2016
    7
    Hi all,
    I am trying to set up a cable to send programs to our 2005 Haas VF-2. It'll be a 25 pin male on both ends. My question is, should they be pinned the same on both ends? I'm fine using software handshakes for now, so I will not be putting jumped pins in. I've been looking around all day and haven't come up with any info on going 25 male to 25 male. The manual says...
    Female
    Pin 1 - Ground
    Pin 2 - Red
    Pin 3 - Black
    Pin 7 - Green
    Male
    Pin 1 - Ground
    Pin 2 - Black
    Pin 3 - Red
    Pin 7 - Green
    However this is not a configuration I'd be able to use, as the switch has a female out.
    Thanks for any help
    Feb 2009
    6028
    Re: Haas VF-2 RS-232 Cable Using a Switch
    You would need pins 2 and 3 swapped. I would also caution heavily against using switches. Seen PLENTY of blown comm ports from those. USB to Serial adapters are like $10 now days, just set up individual comm ports for each machine. Much safer.
    Dec 2016
    7
    Quote Originally Posted by underthetire View Post
    Thanks for the reply. I actually ended up pulling the female 25 pin port out of the switch and soldered it into my cable. That way I could use a USB to serial. Works great!
  1. NPN Proximity Switch Extension Cable
    By Sterob in forum Australia, New Zealand Club House
    Last Post: 05-13-2019, 01:14 PM
  2. rj11 limit switch wiring through cable chain
    By alan_3301 in forum Open Source CNC Machine Designs
    Last Post: 10-26-2012, 02:53 PM
  3. CNC Mach3 USB Key Board(Compact Type) Cable Switch
    By Robiz in forum News Announcements
    Last Post: 06-28-2011, 03:21 PM
  4. Home/Limit switch Cable HELP!!!
    By planekrazie in forum DIY CNC Router Table Machines
    Last Post: 04-28-2009, 01:40 AM
  5. limit switch wiring with shielded cable
    By endgrainguy in forum CNC Machine Related Electronics
    Last Post: 05-05-2008, 06:22 AM
