586,581 active members*
2,654 visitors online*
IndustryArena Forum > MetalWorking Machines > Mori Seiki Machines > Mori Seiki Mills > Mori Seiki MV-40M Way Cover Size? And Wiper/ Plastic in back?
    Aug 2019
    I need to know the proper dimensions for the Mori Seiki MV-40M front Way Cover. I need to replace it but cannot take it off the machine for down time. I know it's 36" width with 5 pieces/ slides to it.
    Also the back plastic piece at the bottom of the backplate is about 62" in width and I don't know what it's purpose is but it's there and it's brittle and cracked so I need to replace it but don't know the exact dimension in length. It's bolted on there.
    If somebody could give me exact dimensions for these 2 things I would be very thankful.
    Feb 2009
    6028
    Re: Mori Seiki MV-40M Way Cover Size? And Wiper/ Plastic in back?
    Um, without modeling it, its gonna be tough. There is a lot more underneath the top than you'd think. I've had sheetmetal shops fab new panels for them in a pinch, and I had a source for new wiper material, but no one i've known has actually made a complete cover. BTW just the rubber wiper set from Mori for a single cover can be >800.00
    Aug 2019
    Jeez... Okay. It's a Mori Seiki MV-40M MF-M7 if that helps. I'm kind of stuck, hoping maybe somebody has replaced it and measured it before. I can't have the machine down so I'm trying to buy a new one from a company but they want me to send it in and I can't.
    Aug 2011
    92
    I was just looking for wipers for my 89 mv-40b. The wiper in there was a close match to a WIM19 from BUWW.
    I called several venders and it was mind bogling how much the wiper material can be. Quoted anywhere from 45-90 per meter
    Mori does stock the wipers and its about 600 / way cover set.
    Mar 2016
    11
    Hello!!I have a mv40m machine with a faulty ex1047 machine spec.pram.cleared, can you give me the file parameter. My email buinam.90tn@gmail
    Aug 2019
    27
    Someone can help me please. I was change my control of my MV-40B because my NC module has broken. I has backup parameter and some other settings. But unfortunately i forgot to backup the ladder program. Can someone send me the ladder please. Mori Seiki MV-40B MSC-518. Please email me.
    Bagas
    [email protected]
