586,903 active members*
2,753 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > Hypertherm Plasma > Powermax 105 Torchmate Machine to Hand Torch
    Mar 2010
    68
    I have a Hypertherm PowerMax 105 connected to a Torchmate 5x10 table with a machine torch. How do I use a hand held torch to just make quick cuts from scrap? Do I have to unplug the cnc control cables from the back? Then just plug in the hand torch. Or can I leave everything hooked up and just change out the machine torch to the handheld torch but not turn on the program? Thanks in advance.
    Jan 2008
    2247
    Re: Powermax 105 Torchmate Machine to Hand Torch
    Unplug the machine torch, plug in the hand torch. Connect the work clamp to what you need to cut, start cutting. When the machine torch is plugged in it will only fire from a signal through the rear panel CPC port on the Powermax105. When the hand torch is plugged in it will only fire from its trigger switch. There is no need to unplug the CPC connector from the Powermax when using the hand torch. Jim Colt
    Mar 2010
    68
    Quote Originally Posted by jimcolt View Post
    Straight from the man. Thanks so much for the quick response
  1. powermax 45 interface cable with hand torch
    By jayrod7387 in forum Hypertherm Plasma
    Last Post: 01-06-2015, 10:31 PM
  2. PowerMAX 45 with hand torch in mechanized machine.
    By dck in forum Hypertherm Plasma
    Last Post: 11-30-2014, 03:47 PM
  3. Powermax 1000 Hand torch on a CNC Plasma table
    By rogerfries in forum Hypertherm Plasma
    Last Post: 08-02-2012, 12:23 AM
  4. Powermax 65 machine torch on Torchmate 2
    By FunWestTexan in forum Hypertherm Plasma
    Last Post: 01-18-2012, 03:39 PM
  5. hypertherm 1000 hand torch to machine torch
    By duraflap in forum Hypertherm Plasma
    Last Post: 05-18-2010, 08:34 PM
