586,608 active members*
3,621 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Switch from g-code system B to g-code system A?
Results 1 to 5 of 5
    Dec 2005
    504
    I assumed my 0T-A being so old was using g-code system A, but I've had to swap around some stuff like G50 for G92 and G32 for G33. Clearly this is a system B machine. Can this be switched to system A using a parameter? I've looked through the parameters but I didn't find anything obvious. Or is it burned into the eprom?
    Of course I can live with it, it just makes looking stuff up in my manual a real pain. I spent the better part of the day trying to get a G32 tapping routine to work only to finally swap for G33 and I was tapping.
    2932
    Re: Switch from g-code system B to g-code system A?
    I have a 0-T model C/D manual that specifies PRM 0036 bits 1 and 5 determine which G-Code system is used. It MAY be the same on the 0T-A and B... no guarantees.
    Dec 2005
    504
    The parameter descriptions in the manual end at 032 and start again at 100 but the machine has 033-040. I wonder if my manual is missing a page. According to the numbering it isn't.
    2932
    Are you looking in the Parameter Manual or the Operator's Manual? There's also a blurb in my 0T-A Operator's manual at the start of the "Preparatory Functions" that refers to the parameters for G-Code System selection.
    Dec 2005
    504
    I'm looking in the Operator's Manual which contains a maintenance section with all the parameters. I found the blurb on standard and special g-code. My manual doesn't list how to toggle it. I guess I'll need to find a parameter specific manual.
  1. M Code computer system help.
    By willheg in forum LinuxCNC (formerly EMC2)
    Last Post: 06-05-2017, 06:30 AM
  2. Fanuc g code system
    By freemanxxx in forum Fanuc
    Last Post: 10-14-2015, 11:28 AM
  3. Replies: 3
    Last Post: 12-06-2011, 01:12 AM
  4. System variable #4113 for M-code
    By sinha_nsit in forum Fanuc
    Last Post: 10-14-2009, 05:03 PM
  5. FANUC SYSTEM 10 Fault code!?!?
    By will_eng in forum Fanuc
    Last Post: 08-26-2005, 06:36 PM
