586,281 active members*
4,582 visitors online*
    Jun 2006
    44
    Mazak T1 Alarms
    Hello,
    A friend of mine reciently purchased a used Mazak Lathe with a Mazatrol T1 control. He bought at an auction so he has never seen the machine under power. Anyway he has powered it up and asked me would I have a look at it. There's two alarms on and they won't clear, alarm : 28 and alarm : 55 one says emergency stop and the other says motor overload I think. I'm just wondering how to clear them.
    Mark.
    24221
    The E-stop is probabally caused by the OL, this is probabally the spindle OL in the SP drive unit, If you have the big Mitsubishi DC drive, take the front cover off (4 screws) behind it is the Non-Fused Breaker, also while you have the cover off look at the small black flag fuse on the top left of the front board.
    When you power up, look at the status LED's on the front PCB.
    Al.
    Jun 2006
    44
    Thanks Very much Al. I'll try that in the next few days.
    Jun 2007
    17
    when you power it up, and don't move any axis or turn the spindle on you get that? are any of the parameters messed up? we just had a bunch of parameters showing up on our machine as "******" and that was causing a bunch of alarms to turn on.
    if the drive light indicate it's alright may be a parameter issue
  1. Fanuc 21-tb alarms
    By Hlynur in forum Fanuc
    Last Post: 12-06-2012, 04:44 AM
  2. Mazak alarms strike again
    By trademarkmachin in forum DNC Problems and Solutions
    Last Post: 09-02-2007, 09:05 AM
  3. Mazak QT-200,Mazak VTC-160A,Mazak FJV-250 all pcb problem
    By sting_dot in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-22-2007, 02:20 AM
  4. mazatrol cam m2 alarms
    By gasto in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-27-2007, 08:16 PM
  5. Fanuc 6MB 401 and 410 alarms
    By john braks in forum Fanuc
    Last Post: 02-24-2006, 07:45 AM
