586,762 active members*
7,815 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > Differences between HTD, GT, AT and T pulleys?
Page 1 of 3 123
Results 1 to 20 of 42
    Jul 2005
    298
    Question Differences between HTD, GT, AT and T pulleys?
    Anyone care to give me a bit of noob education on the differences between common pulley/belt profiles? From what I've found, the GT and AT profiles are better for linear positioning than the HTD and T profiles respectively, but otherwise I'm struggling find more info on "what" the different profiles are good for.
    Ultimately, I'm looking at creating a slow/high torque 4th axis for a CNC machine.
    My current plan is to drive a 60 Tooth AT5 Pulley from a 20 Tooth AT5; using a 25mm wide belt. The input (on the 20 tooth) would be anything up to 120rpm and 10Nm of torque (so approx 40rpm and 30Nm on the 60 tooth output).
    I'm not needing to hold metalworking levels of tolerance (it's a woodworking machine), but obviously I don't want it slipping or snapping belts.
    Am I being realistic with the above, should I be looking at a different profile and/or thinner or thicker belt?
    Jul 2018
    6434
    Re: Differences between HTD, GT, AT and T pulleys?
    Hi Sploo - GT and HTD profiles were developed for power transmission and are not ideal for positioning applications. T and AT were developed later. I recommend you use an ATL belt profile which is stiffer then the AT for the same size (uses AT pulleys) and its teeth are more accurate. ATL belts are designed for positioning applications and are compensated for the extra preload a positioning application requires. The size you discuss should be OK without dong the math if your up to the math see attached.. . Cheers Peter S
    Jul 2005
    298
    Quote Originally Posted by peteeng View Post
    That looks very useful; many thanks. From a quick scan through it also appears to discuss the number of belt teeth engaged on a pulley; which was a concern I had with my design of a 3:1 pulley ratio at fairly close centre-to-centre distances. Plenty for me to read!
    Jul 2018
    6434
    Hi Sploo - 3:1 will work fine. Higher then that and teeth count can be a issue. All explained in the docs...Peter
    15362
    GT series is the closest tolerance Timing pulleys and belts that are made and are used where you need accurate positioning
    AT profile will work fine for what he wants to do but are not as accurate as the GT series
    Mactec54
    Jul 2018
    6434
    Hi Mactec - You have put forward the GT in other threads as the best choice and that it has the least backlash. But none of the manufacturers recommend GT as a linear drive solution only power drives (although it is used by many for the application) . So is there a manual or data you can provide to explain this? The ATL belt is the only belt profile specific to positioning drives...as far as I can find. Peter
    1943
    Simple:
    https://assets.gates.com/content/dam...17195_2014.pdf
    Jul 2018
    6434
    Hi 109J - Thanks, but that doc does not discuss positional applications or how to design a GT for a positional application. Although at the end it has a few diagrams showing belts being used in this sort of application the doc does not cover it. It does mention linear drives but in applications that are not positional critical. GT belts use fiberglass as the reinforcement which is great for strength, fatigue & small pulleys etc but means they are not as stiff as steel belted AT or ATL belts of the same size. I looked around for the specific stiffness of the GT belts but couldn't find it. Also the specific strength of the belt is not discussed in the doc as it covers power transmission apps. For positional apps the preload of the belt is much higher and has to be calculated differently to a power app as well. So I'll stick with AT's or ATL's Peter
    fibreglass E=70GPa
    steel E=200Gpa approx 3x stiffer for same cross area.
    Jul 2005
    298
    Very useful info all - many thanks.
    I haven't had chance to go through the docs Peter posted yet - so a question in case it's not mentioned; the AT5 pulleys I've been looking at have flanges up to the 42 tooth option, then the 44, 48 and 60 do not have flanges (though the vendor can add them).
    If I were using a 25mm belt between a 20 tooth and 60 tooth pulley (diameters roughly 32mm and 95mm respectively, with a centre-to-centre distance of maybe 100mm) would I be needing flanges on the 60 tooth pulley, or would it likely be unnecessary? The additional cost of the flanges is tiny, and I have space, so there's nothing stopping me doing it.
    Jul 2018
    6434
    Hi Sploo - I've always used flanges both sides, but with the short span, not having a flange on the big one should not matter. But you will need to have the shafts parallel and pulleys true for it to work correctly. Avid don't have a flange on the big side...see attached. Peter
    15362
    fibreglass E=70GPa
    You are good at posting numbers but have no real experience with these belt here is a PDF and I have many of then on this subject your AT belt profile is old hat, and out dated, yes it is still used but does not compare to the GT series Belts in any way take a look at the numbers in this PDF
    You can get any type of Timing Belt profile with different cord designs and materials, you chose the material and cord for the job you are doing, you are not stuck with one cord type saying the ATL steel is better is total BS you can have steel cords in any profile if there was a need
    Mactec54
    15362
    Quote Originally Posted by sploo View Post
    If the cost is not much then go with the flanges they are also easy to fit flanges at any time if you have access to a lathe
    Mactec54
    Jul 2018
    6434
    Hello Martec - I've been using timing belts for various applications for about 30 years. All I need is evidence not statements. So thank you for the document I shall read it with interest. Of course you can have any cord you like in a belt I have one here with gold cords just comes down to how big your chequebook is and the application requirements. In this case its best to stay with std readily available solutions. Peter
    Jul 2005
    298
    Is the GT standard more common in the US? I'm in the UK and there doesn't seem to be many sources for GT5. There's a fair bit for GT2, which I guess might be common in 3D printers or small CNC machines?
    I can get the imperial L, XL and H, but otherwise it's mostly T, AT, and HTD.
    Jul 2018
    6434
    Hi Sploo - Here's a chart with the mentioned profiles on it. GT is a gates proprietary profile, whereas the others are industry stds. I'm not hung up on the profile just I like to make decisions based on engineering data or experience. Gates provide a lot of data but in this case don't seem to publish the specific stiffness of the belt. Which is the number I'm interested in for positional or registration applications. I want the stiffest smallest belt possible. Looking at the Mectrol document they have a chart (see extract below) with all the industry sections on it, unfortunately not the GT and none of the Gates docs linked so far have this in them either. I'm sure whatever belt you pick will be fine. Cheers Peter
    Jul 2018
    6434
    Hi all - See the attached extract from a gates design manual. It states that the GT profile has better backlash characteristics then an HTD belt but not as good as their timing belts. So for positional applications maybe consider another profile, anyone has the specific stiffness data for GT belts would be good to share...I'm always looking for a better solution eg the Gates carbon fibre belts look promising... Peter
    Jul 2005
    298
    I found a couple of other useful resources; this (https://www.apexdyna.nl/en/the-right-timing-belt/) is a company based in Holland (so it'll have a Euro perspective) but seems to confirm that AT is good for my needs, and that GT is better known in the US market.
    The Reprap wiki (https://reprap.org/wiki/Choosing_Belts_and_Pulleys) advises GT2 over T belts; which makes sense, and also perhaps confirms my guess that the better availability of the GT2 and GT3 parts in the UK is down to the popularity of 3D printers.
    Given the relative lack of GT5 and GT10 here in the UK I'll proceed with AT. I've not found a suitable ATL belt yet (which I understand works with AT pulleys, and is even better than AT belts), but I am working my way through the various equations in the doc posted by Peter (which is proving very useful).
    15362
    GT-2 and GT-3 series are the same, it was just a patent change GT-2 became GT-3, AT profile is the world over the GT series is also, if you know where to look, you don't need a ATL belt the belt won't change the backlash the AT Belts Pulleys have, and for what you are doing a regular AT Belt will work, the snip below tells you which Timing Belt is superior under tension and how much tension load each can take
    You can see how wimpy the AT is in comparison
    Mactec54
    Jul 2005
    298
    That's T not AT though isn't it?
    15362
    Yes T series is 40 Degree tooth the AT is 50 Degree tooth apart from that not much difference
    Mactec54
Page 1 of 3 123
  1. NM-135 X and Y differences
    By tas99 in forum Novakon
    Last Post: 02-12-2021, 10:17 PM
  2. Differences from V23 to V24
    By hkenuam in forum BobCad-Cam
    Last Post: 11-18-2011, 05:56 PM
  3. Differences
    By Markus777 in forum SIEMENS -> Sinumerik 802D/808D/810D/828D/840D
    Last Post: 09-19-2008, 04:27 PM
  4. g-rex 100 101 differences?
    By h_2_o in forum Gecko Drives
    Last Post: 02-28-2006, 07:03 AM
  5. Poly pulleys vs steel pulleys
    By ynneb in forum DIY CNC Router Table Machines
    Last Post: 03-10-2004, 04:01 AM
