586,655 active members*
4,561 visitors online*
    V22 / 23 / 24 Postprocessor
    Hello out there,
    does anyone have a valid *.MillPst file that can be edited with the original postprocessor editor (MillEditPost.exe) that came with V22?
    I used to work with V22 a long time ago and bought V24 for private use when it was new. But after this long time I can’t find my self made postprocessors anymore.
    All I need is one valid V22 *.MillPst file. It does not matter what machine control type, as I will edit it myself. I tried editing a V24 post with MillEditPost.exe but the tree view in the “Edit code blocks” window is missing all the text. (See Image)
    Thank you in advance for any help.
    <!--sizeo:2--><span style="font-size:10pt;line-height:100%"><!--/sizeo-->David Frühling<!--sizec--></span><!--/sizec--><br /><b><!--sizeo:2--><span style="font-size:10pt;line-height:100%"><!--/sizeo-->ER<!--sizec--></span><!--/sizec--></b><!--sizeo:2--><span style="font-size:10pt;line-height:100%"><!--/sizeo-->LAS Erlanger Lasertechnik GmbH<br />Arbeitsvorbereitung<br />Kraftwerkstrasse 26<!--sizec--></span><!--/sizec--><!--sizeo:2--><span style="font-size:10pt;line-height:100%"><!--/sizeo--><br />D-91056 Erlangen, Germany<!--sizec--></span><!--/sizec--> <br /><br /><br /><!--sizeo:1--><span style="font-size:8pt;line-height:100%"><!--/sizeo--><!--coloro:#000080--><span style="color:#000080"><!--/coloro--> <a href="http://www.xing.com/profile/David_Fruehling" target="_blank"><img src="http://www.xing.com/img/buttons/6_de_btn.gif" border="0" class="linked-sig-image" /></a><br /> <!--colorc--></span><!--/colorc--><!--sizec--></span><!--/sizec-->
    Re: V22 / 23 / 24 Postprocessor
    Just found this forum. Did you ever find a Post? I have post that works with V21, maybe V22 also. Looking for a copy of MillPostEdit.exe. Do you still have that?
