586,596 active members*
3,106 visitors online*
IndustryArena Forum > MetalWorking Machines > Turning Machines > Grizzly G0765 lathe and HDPE Rod turning?
    Jul 2019
    Im wondering if anyone here has experience with either a G0765 7”x14” lathe and turning HDPE rod on said lathe?
    Im having trouble figuring what tools/cutter to use so i can get a smooth surface, right now i have HSS bit squares but i need to know the best angles to grind for a smooth cut any help is much appreciated???
    Dec 2013
    5717
    Re: Grizzly G0765 lathe and HDPE Rod turning?
    For soft materials normally a high shear angles are prefered. Think knife blade rather than cold chisel. A generous nose radius is helpful also. Experiment a bit and see what works best for you.
    Jim Dawson
    Sandy, Oregon, USA
    May 2015
    686
    I've machined thousands of parts from HDPE. I found that the finish improved out of sight when I upgraded to a 13" lathe with a power cross slide and used CCMT insert tooling. I run as fast as the lathe allows.
    Rod Webster
    www.vehiclemods.net.au
    Jul 2019
    Thanks guys! I shoulda elaborated on the subject a bit more tho this lathe is at my job (i work with acrylic) and the parts im making are for a customer we have so im jus tryin to learn as much as i can about a subject of little interest in, ive been grinding different angles to see but i thot I could get the answer much faster anywho Thanks!
