586,398 active members*
3,057 visitors online*
Thread: rapid speed
Results 1 to 7 of 7
    Jun 2006
    53
    rapid speed
    Just curious, I have a 1985 boss 5 with a mach 3 retro, original steppers. I run my rapid (g0) speed at 50 ipm. I am curious what rapid speed others are running on a similar machine.
    1121
    didn't it originally do at least 100?
    Oct 2006
    735
    I've only jogged around with mine so far playing and getting things setup but I've seen it do 200+ jogging. That is screeming fast to me seeing I only have my round pole conversion set to ~50 fast. My router mill does 400/200 fast depending on he axis..
    but to see a 40 some " table move that quick looks real fast..hehe
    I think with the gecko conversion you would have to limit your top speed to what ever breaking speeds your gecko's could handle (slowing down that much weight) with out breaking any of the electronics inside. Not sure if a break resistor would be needed or a good idea. If I ever convert mine to gecko control it's something I'd have to look into and know others have talked about it.
    no idea how that would be calculated though.
    b.
    1121
    It won't seem fast soon.
    Watch my big machine run at 2750ipm and everything else is just pokey
    Truthfully, accel and decel are where real speed can be found. If you can get the ramps to run fast, you will see real throughput increase
    Oct 2006
    735
    The trick is to be able to feed work to a fast machine that fast..hehe
    b.
    Jul 2005
    195
    I'm running mine at 2010mm/min (80ipm). Boss 6.1, metric machine, original drives and steppers running off Mach3 so not sure if it's comparable.
    1121
    dunno how you guys stay awake waiting for your machine to be done......
  1. Rapid to (# set by Parameter) What's yours?
    By Scott_bob in forum G-Code Programing
    Last Post: 09-01-2021, 06:05 PM
  2. G-Zero by Rapid Output!!!!!
    By tobyaxis in forum Uncategorised CAM Discussion
    Last Post: 02-05-2007, 05:16 AM
  3. Rapid moves G00
    By dicksonhof in forum Mach Software (ArtSoft software)
    Last Post: 11-07-2006, 04:21 PM
  4. BPSeriesI / Centroid control- Spindle speed all out of whack with speed dial?
    By peter.blais in forum Bridgeport / Hardinge Mills
    Last Post: 08-08-2006, 09:29 AM
  5. New Taig, 8 ipm maximum rapid speed?
    By fivaxis in forum Taig Mills / Lathes
    Last Post: 05-11-2006, 02:55 PM
