586,655 active members*
2,961 visitors online*
    Jun 2019
    YASKAWA SGDM-15DN pc connection issues
    Hi Guys
    I am having major issues trying to connect this drive to a PC, newest software, correct cable config and it wont connect using 2 seperate pc's, 3 seperate usb to rs232 serial adapters, 2 of the same drive, is there something i am missing?
    what should be a simple transfer parameter exercise is extremely frustrating.. anyone with experience with this drive?
    pc Lenevo T430s running win 7 64 bit
    comms speed 9600
    7 bit
    parity even
    stop bit 1
    software sigmawin+ 5.75
    any help would be appreciated
    Nov 2017
    4
    Re: YASKAWA SGDM-15DN pc connection issues
    No experience with this drive , but had plenty of issues with different USB to serial converters. The best solution I found was to just get an old PC with RS232 and transfer files to it from a modern PC and the to the device. Hope this helps.
    Sep 2018
    35
    Im not familiar with this unit either, but I do know that usb to serial on win7 is a pain in the ass, if you can get it working at all, just having a quick squiz thru your manual states you should connect it with this cable, JZSP-CMS01 , https://www.ebay.com/itm/NEW-Yaskawa...-/173579784109.
    Hope this is helpful
    Jan 2008
    13
    hello,please i have same problem servo sgdm-10dn . please how to solve??
    regards
    May 2016
    26
    Could you solve the problem?
    I’m using COMMUNICATION SOFTWARE FOR FANUC CNC with the similar CNC.
    It is specially designed for FANUC CNC though it can be used also with other CNC.
    It has several built-in help menus that show you how to use it with your CNC.
    You can download it from “The SOFTPEDIA· web page.
  1. 610 plus connection issues
    By IdeaFactory in forum Multicam Machines
    Last Post: 09-27-2012, 05:01 PM
  2. CONNECTION ISSUES TNC355 to PC
    By pafi in forum DNC Problems and Solutions
    Last Post: 06-26-2012, 06:17 PM
  3. Connection to Drive [tuning] issues
    By JerryFlyGuy in forum CNC Machine Related Electronics
    Last Post: 11-07-2011, 10:28 PM
  4. Yaksawa SGDH Drive and motor BRAKE ???
    By kben77 in forum Servo Motors / Drives
    Last Post: 11-15-2010, 09:30 PM
  5. RS232 connection issues to Milltronics Partner V
    By Jeff S in forum Milltronics
    Last Post: 03-16-2007, 12:34 PM
