586,103 active members*
3,339 visitors online*
    Jan 2007
    25
    Setup Help, CNC refit
    Just my second post here guys but here is what I have and what I have done.
    I have owned 1 Mill and several Lathes before now and know machining basics. (Smithy Mill, sherline to Jet 1340 lathe) Really just enough to get me into and out of trouble
    I had a nice Wabeco CNC mill all setup but had a fire which distroyed the Wabeco and the 1340 Lathe. I have now refit the Wabeco 1210E (less cnc) and pickuped a nice Emco Maximat in the meantime. I also picked up a Speedway 7x12 and a HF Mini Drill/Mill (Sieg X1?)
    I need to setup the complete CNC side of the Mill now. I have the stepers, but that is it. I plan on using it for one-of parts really, but may do small runs since I do alot of RC Aircraft too.
    After reading hundreds of posts here and other forums I am still unsure of which way to go. I need controllers/PS and all the wiring still and have looked at few links here, but still confused.
    I had ONECNC before, but never got to use it. I did like the options and upgrades but don't think it is in my price range from recent posts now.
    Suggestions to retailers, threads and complete setups are welcome. I really need to understand the setup from A to B.
    Thanks in Advance
    JR
    Aug 2007
    21
    You might try contacting Fagor. They have retrofit and conversion kits and they will walk you through it.
  1. Wire EDM refit control
    By Karl_T in forum CamSoft Products
    Last Post: 09-23-2010, 02:53 PM
  2. Bridgeport boss5 refit
    By paulsoncd1@juno in forum Uncategorised MetalWorking Machines
    Last Post: 01-17-2007, 12:46 AM
  3. What is your setup?
    By dolanosa in forum CNC Wire Foam Cutter Machines
    Last Post: 10-09-2005, 08:00 AM
  4. Setup
    By ACME in forum Uncategorised MetalWorking Machines
    Last Post: 09-07-2004, 03:37 PM
  5. Anyone know anything about this setup?
    By efreak in forum DIY CNC Router Table Machines
    Last Post: 08-29-2004, 06:27 AM
