Re: Quality affordable Closed loop Controller
I personally think that there are so many areas that inaccuracies can creep in in your design that worrying about encoders in your design is just adding additional complexity and cost that is not required. I would not be a fan of the extrusions for the gantry and worry about the flimsy gantry ends.
As far as the controller goes, you could do a lot worse than Linuxcnc. Pair it with a Mesa 7i76e 5 axis ethernet board with spindle control (or the cheaper Mesa 7i96 with fewer inputs) and you will have a high performance, gantry friendly system as LinuxCNC will square the gantry when it homes. I've been running my 1220mm x 1280mm plasma table without encoders with this setup and its really awesome. Its spot on accurate and I've never had accuracy issues even at up to 21 m/min. In my experience optimising for maximum speed and accelleration which plasma requires, if you are missing steps, you are exceeding the design parameters of the steppers.
I've never played with encoders but it is my understanding that you start missing steps whan you have no torque so the steppers can't catchup the missing steps.
Rod Webster
www.vehiclemods.net.au
