586,594 active members*
2,724 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Taig Mills / Lathes > How to remove travel stop post on Taig mill
    Feb 2004
    33
    I want to remove the travel stop post. I removed the cross screw completely, but I still cant get the post out. Does anyone know if this is pressed in, and needs to be removed by removing the table, flipping it over, and pressing it out from the underside? I hope not... Any ideas?
    Thanks, Nick.
    Attachment 421662
    Jun 2011
    68
    Re: How to remove travel stop post on Taig mill
    Here is a photo of my old saddle( replace with ball-screw conversion)
    Yes, it is pressed in but not extremely tight.
    The pin smooth, not knurled . So a couple of light taps will get out.
    The easiest way to pull the saddle off is to, first center the x axis.
    Move the saddle to front of the mill, close to the y-axis stepper.
    Remove the x and Y stepper motors.
    Remove the 2 capscrews the secure the y-axis stepper bearing housing.
    Now you can slide the Saddle with x-axis table off....
    Good Luck,
    Stuart
    Feb 2004
    33
    Thank you for the info. Before I saw your reply, I had found another thread that said taking it out is like pulling teeth, and if you do take it out, you have to plug the hole or the leadscrew will get full of chips. Thus, I decided to cut it off and leave its bottom installed.
    ps, do you think the ballscrew was a worthwhile upgrade?
    Attachment 422640
    The other thread said to mill it off. I found that was not possible with a 1/2" end mill, as the spindle does not line up with the pin.
    Attachment 422642
    I decided to cut it with a Dremel. That worked well.
    Attachment 422644
    Interestingly, after I cut it off, my X axis was binding like crazy and the stepper could barely move. I traced it to the screw holding the pin in place. If I tightened the screw even slightly more than finger tight, it was binding bad. Loosen it a half turn from that point, and all was back to normal. I don't know what happened, as this screw was probably pretty tight before I messed with this whole idea of removing the pin. It works great now, but certainly a head scratcher.
    May 2013
    480
    the screw was probably pressing on the gib or it was distorting the aluminum and pushing on the gib
    Jun 2011
    68
    Quote Originally Posted by daytrader View Post
    Yes...
    Backlash is almost non-existant
    Able tighten up the gibs no stalling
    Rapids are blazingly fast!
    Suart
  1. Weird Seemingly useless part on CNC Taig Mill, Can I remove this? (pic)
    By scubasteve_911 in forum Taig Mills / Lathes
    Last Post: 10-08-2014, 04:30 AM
  2. how to remove chuck from Taig rotary table?
    By dwneumann in forum Taig Mills / Lathes
    Last Post: 11-15-2012, 11:04 AM
  3. Extra .500" Y Travel on a Taig
    By JoeDawg in forum Taig Mills / Lathes
    Last Post: 01-10-2009, 11:56 PM
  4. Taig actual travel
    By TMaster in forum Taig Mills / Lathes
    Last Post: 04-07-2006, 12:56 AM
  5. More Z travel please, For a Taig Mini Mill
    By MrRage in forum Taig Mills / Lathes
    Last Post: 11-03-2005, 09:46 PM
