587,006 active members*
3,174 visitors online*
Results 1 to 12 of 12
    Jan 2007
    1332
    Tapping a 6-32UN hole
    Tapped a single 6-32UN hole. The real issue was how to hold a large odd shaped part and locate, drill hole, and tap the 6-32 hole. My solution was to use the same fixture made to hold the part horizontally on the mill, to be held vertically in the 6 inch vise on the mill. One of the problems with this was the tapped hole goes thru one of the three 3/8" holes used with Mite-bite XYZ expansion pins that hold the part. I used a small Sherline mill hold down clamp to replace one of the XYZ pins. Also used 2-4-6 blocks to beef up the jaws on the 6 inch mill vise. The other issue was with this setup had very limited Z height with holding the tap and drilling the holes. I wound up using a 6-32 Balax form tap in a Starrett 93A T tap handle with a Fisher micro tap guide. I normally hold the Fisher micro tap guide in a 1/2" TTS end mill holder however that was too tall to fit the limited Z height available. Even using a 1/2" R8 collet didn't clear up enough Z height. I solved this issue by machining a 3/4" low profile 1/2" holder which allowed the Fisher micro tap guide to fit up inside the holder and free up Z height.
    Don
    Using an edge finder held in a TTS ER 20 holder to locate the center using a 3/8" dowel pin
    Attachment 421120
    Spot Drill
    Attachment 421122
    1/8" parabolic flute drill held in a TTS ER 20 holder
    Attachment 421124
    partial depth hole using #27 drill for clearance
    Attachment 421126
    6-32 form tap held in T tap handle with micro tap guide
    Attachment 421128
    Modified 3/4" tool holder with micro tap guide
    Attachment 421130
    Nov 2012
    591
    Re: Tapping a 6-32UN hole
    Have you tried thread milling? I've found that it works super great!
    The Fusion 360 Thread program generates fine tool paths, once you tune it in.
    The two things to pay most attention to is setting the "diameter offset" to the same value as your thread pitch (for standard threads,) and turning on "lead to center" in the linking settings.
    Micro 100 has some reasonably affordable single point thread mills. The 100 tool might be about right for 1/8" clearance #6 threads? https://amzn.to/2KdHZx8 Or the 120 tool (TM-120-8) I've used their 180 tool for M6, and their 250 tool for M10 threads. I've also used a Sandvik Coromant M2.5 thread mill, which has multiple teeth and thus can only do exactly 0.45mm pitch, but it cuts nicely, with no special preparation, cooling, or holding solution needed. Tool pressure is quite minimal, too.
    Yes, thread mills are more expensive than taps, but I haven't had one thread mill break yet, and if it does, it's smaller than the clearance hole and thus just falls out without ruining the part.
    I'm a convert, and big fan :-)
    Jan 2007
    1332
    Quote Originally Posted by jwatte View Post
    Yep I thread mill on threads greater than 1/4 or M6. For aluminum and smaller threads like 4-40 I find Balax form tap in a Procunier tapping head works extremely well for me. Not only are the threads forged and thus stronger there is no chips to deal with. Unfortunately in this case I didn't have the headroom to use the Procunier. BTW I converted a 3/4" SS Vardex insert thread milling tool to TTS.
    Don
    Attachment 421138
    Attachment 421140
    Mar 2009
    1863
    Tapping on the 1100 is an absolute piece of cake. I’ve done threads as small as 2-56 on my machine. Heck with that hand tapping crap.
    Jan 2007
    1332
    Quote Originally Posted by Steve Seebold View Post
    I do it all the time with my Procunier tapping head with the 1100. I have tapped 10s of thousands of blind 4-40 holes really fast with the Procunier tapping head on the 1100 and lots of 2-56 blind holes too. However if one actually bothered read my post I had no Z -axis head room for the Procunier tapping head and hand tapping worked very well in this case particularly since it was only one 6-32 hole.
    Don
    Nov 2007
    2151
    I didn't have to read your post to understand that . Both types of T.C. units that Tormach sells will not work either from what I was seeing, and a Procunier head is even bigger. I like the collar on your single pass multi point threading tool. Been thinking about buying a couple 3/4 inch shank 1 to 4 insert endmills and put collars on them. Tormach's Sheer hog system is priced a little rich for me. I also use a spring loaded tap guide mounted in a TTS Holder. Tapping tough materials and only a few holes, imho there will be far less drama and pucker factor involved.
    Nov 2012
    591
    If you have, and can fit, a Procunier, it's a great option, especially if the tapping isn't part of an elaborate multi-tool-change flow.
    My point is that a thread mill gives you more vertical space, and doesn't need any customer workholding (ER20 works fine!)
    (Also, mine is a 440, so I can't even reverse the spindle, which also limits my options ...)
    Mar 2009
    1863
    I use the ER16 T/C tapping head. I’ve developed a problem that allows me to tap holes as small as 2-56 on my 1100 and the T/C tapping head takes up a lot less room than the Procunier tapping head.
    Dec 2008
    740
    I’ve developed a problem ..
    Is this something you'd like to talk about???
    Sorry, I just couldn't resist
    Step
    Jan 2007
    1332
    Quote Originally Posted by mountaindew View Post
    Exactly. That's what I just did tapping a 4-40 hole in a SS part. Had plenty of head room this time but since this is a one off part and difficult SS material I used the Fisher micro tap guide in a TTS 1/2" holder with Starrett 93A T-handle tap holder to hand tap. Brought out my special ingredient for tapping SS (in addition to a new Brubaker 4-40 cutting tap) the Old Tap Magic with 1,1,1-trichloroethane. I use my Tormach for both prototyping and limited production. With the shuttle jog controller prototyping on the Tormach is just like using a manual mill with hand wheels. And if I have a one off part that is quickly made by hand tapping that's what I do. BTW I only use the old Tap Magic using plenty of ventilation i.e. shop door open.
    Don
    This is the view yesterday from in front of my Tormach with the shop doors opened. BTW it snowed last week. This week perfect.
    Attachment 421314
    Special Tapping ingredient for SS
    Attachment 421312
    Jun 2014
    1780
    Quote Originally Posted by Don Clement View Post
    Don
    The old formula tap magic brings back many memories, in the late 60's early 70's thdey wouldnt let us have it in the dairy any longer, this was the best SS tapping fluid ever!
    Edit: I looked it up on Wikipedia and one of its uses is as a solvent for circuit board resist, I may have about a half gallon of that stuff still left over from my circuit board days, I'll have to check that out..............
    mike sr
    Jan 2007
    1332
    Set the WAYBAC to the 1980's when Westec was held every year in DTLA at the convention center with the gigantic night sky star map inlaid on the ground floor. Tap Magic had a demo where one could try one's one hand using Tap Magic for themselves by hand tapping in SS before use and after. (must have been before CARB). The effect of using Tap Magic in the demo sold me. This is when Tap Magic include 1,1,1-trichloroethane. I have a gallon of reagent-grade 1,1,1-trichloroethane and think I will use that when my supply of Tap Magic runs out try using that. BTW I was told this story about a machinist who keep a small bottle with eye dropper of 1,1,2,2-Tetrachloroethane and would put on a drop when tapping really difficult materials. I would use a respirator under a hood using that stuff.
    Don
  1. Tapping a hole with M03 M04 instead of G84
    By Fwp829 in forum Controller & Computer Solutions
    Last Post: 08-18-2014, 09:08 AM
  2. Shallow hole tapping
    By Tippy1 in forum MetalWork Discussion
    Last Post: 03-13-2013, 03:01 PM
  3. Re-tapping a hole VF-7
    By laka in forum Haas Mills
    Last Post: 12-06-2010, 11:01 PM
  4. Single Op Through Hole Tapping
    By GHPoe in forum MetalWork Discussion
    Last Post: 12-20-2008, 07:22 PM
  5. Tapping a hole twice in a HMC
    By Appetite in forum MetalWork Discussion
    Last Post: 05-02-2007, 04:30 PM
