586,721 active members*
3,199 visitors online*
IndustryArena Forum > CAM Software > EdgeCam > EDGECAM ROUGH MILL STARTING WITH AN HELIX MESSAGE
Results 1 to 7 of 7
    Sep 2010
    86
    Hi! Im machining a contour with a small diameter tool using a ROUGH MILL with WAVEFORM strategy. The toolpath is starting on the piece with an helix motion. The setting gives us two option: pre drilled hole and helix. How can i make the toolpath ROUGH MILL WITH WAVEFORM strategy to start from outside to inside ? Thanks in advance !
    Dec 2008
    441
    Re: EDGECAM ROUGH MILL STARTING WITH AN HELIX MESSAGE
    Hi!
    I think your option "stock type" isn`t choosed, if you choose "Current Stock" it should be starting outside of the part. IF you have inserted a stock
    See my attached picture.
    Greetings from Robert
    My second homebuilt cnc machine cnczone.com/forums/norwegian_club_house/123977-ombygget_cnc_-_gecko_540_a.html
    Sep 2010
    86
    Quote Originally Posted by Vegabond View Post
    Hi!
    Hi Robert and thank you very much for your reply. I have tried as you suggested but i still can not get the toolpaths to start from outside to inside . Surely there is something that im missing. Here are attached some files for your consideration.Click image for larger version.
Name:	HELIX APPROACH.PNG
    Sep 2010
    86
Name:	EDGECAM STOCK TYPE.PNG
    Sep 2010
    86
    Quote Originally Posted by mousongie View Post
    Attachment 419952
    Jan 2013
    Are you using a boundary? Try without.
    If you only want to rough the outside, then pick 2 boundaries:-
    The 1st the part profile
    The 2nd a rectangle bigger than the billet - it's size really doesn't matter as long as the cutter can easily fit between it and the billet. You will have manually create this.
    Play with boundary options (in/out etc) in roughing to see different results.
    Dec 2008
    441
    OR milltype from optimized to CLIMB MILL!
  1. Message when starting Nc plot....
    By Tancuda in forum NCPlot G-Code editor / backplotter
    Last Post: 07-09-2015, 02:39 AM
  2. error message during rough flowline or contour
    By George777 in forum Mastercam
    Last Post: 12-22-2009, 01:41 AM
  3. error message starting engine mach 3
    By woffler in forum Mach Software (ArtSoft software)
    Last Post: 01-29-2008, 03:21 AM
