586,788 active members*
2,790 visitors online*
IndustryArena Forum > Employment Opportunity / RFQ (Request for Quote). > RFQ (Request for Quote) > Request for Quote - Laser Cutting Mild Steel 2mm + 4mm UK EU or China
    Apr 2014
    215
    As per the title.
    RFQ for Laser Cutting of small parts from Mild Steel, majority being 4mm, with 1 item being 2mm.
    RFQ preference is for the UK, EU or China as from experience the shipping cost from the USA will be too high including for duty...... but you are welcome to quote if you really want tofrom experiance I suspect that the cost will be prohibitive though.
    All of the quantities are shown in the file name as are the material thicknesses
    All files are within the attached zipped folder.
    Shipping will be to the United Kingdom, post code Liverpool, L1 1DE for the purposes of quotation {the correct and full address will be given at time of order}
    The parts could be 2.5D milled + drilled but I expect that the cost would be higher than high speed laser.
    Re: Request for Quote - Laser Cutting Mild Steel 2mm + 4mm UK EU or China
    I can't open this drawing here.
    Can you send it to me by mail?
    [email protected]
    Thanks?
    Over 30 year in cnc machining parts business.CNC Turning, Milling, Drilling, Planning, Grinding, Welding www.plusminusthree.com Email:[email protected]
    hi, we are manufacturer from china, could you please send the drawing information to [email protected]
    Oct 2019
    6
    hi, if you still have any need please send darwing and detail by email
    [email protected]
    Oct 2019
    37
    Quote Originally Posted by robertspark View Post
    As per the title.
    Hello ,
    we are manufacture of laser cutting or engrave machine.
    Contact me by email:[email protected]
  1. First hand experience cutting mild steel with low cost CO2 laser out there?
    By Soyland in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-22-2020, 08:37 AM
  2. Replies: 0
    Last Post: 11-17-2015, 04:21 AM
  3. Request a Quote: Stainless steel bottle openers
    By Msport in forum RFQ (Request for Quote)
    Last Post: 01-21-2015, 07:02 PM
  4. RFQ - Quote for cnc turning job, EN8 mild steel lot of 500
    By Sheepspeed in forum Employment Opportunity
    Last Post: 11-02-2010, 04:07 PM
  5. Laser/Waterjet Cutting - Quote Request
    By wwendorf in forum Employment Opportunity
    Last Post: 03-27-2008, 08:06 PM
