586,584 active members*
2,628 visitors online*
IndustryArena Forum > MetalWorking > Diemaking / Diecutting > Removing feed-thru punch from wood die board?
    Aug 2014
    35
    I'd like some advice on how to remove a broken feed-thru punch from a wood die board. The punches are only 1/16" thick so there's not much steel to press against when pressing it out. I'm new to this and wanted to get advice on what the standard procedure is before I try pressing them out with some sockets.
    Jun 2010
    4256
    Re: Removing feed-thru punch from wood die board?
    Need photo - it does not appear.
    Cheers
    Roger
    Aug 2014
    35
    Jun 2010
    4256
    Um ...
    What's not visible is how far it is sunk into the timber. That matters.
    Frankly, just looking at it, I would GUESS that brute force and a hammer might be how I would try. Sorry about that.
    Unless of course you can fit a tight mandrel inside it and then apply a bit of torque?
    Cheers
    Roger
  1. cnckad punch off the table euromac BX1000 top punch
    By renatomail in forum Post Processor Files
    Last Post: 10-19-2017, 11:55 AM
  2. Wood speed and feed file
    By edcross in forum BobCad-Cam
    Last Post: 12-17-2016, 09:31 PM
  3. System for fast removing the smell of burning wood from egraved and cuted wooden item
    By tumim in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-13-2016, 11:07 PM
  4. Feed and Speeds for wood
    By analogman in forum DIY CNC Router Table Machines
    Last Post: 01-19-2010, 03:40 PM
  5. Feed rates in wood?
    By nervis1 in forum Uncategorised MetalWorking Machines
    Last Post: 02-13-2004, 03:57 PM
