586,475 active members*
3,299 visitors online*
IndustryArena Forum > CAM Software > Mastercam > program stop to check size
    Apr 2007
    12
    Hey all,
    I was wondering how does someone using mc8 stop program and start it(not using m01) when size is correct?.
    I wnat to finish a diameter but leave .5 to check size then once checked maybe push start?? and program continues.
    Jan 2004
    3154
    insert an M00 in the appropriate place in the program
    www.integratedmechanical.ca
    Sep 2003
    35
    You can setup your post so when you do a "Manually entry" between operations ,your machine will move to its home position and post out a M00, and a comment you added in your "Manual entry"
    G53 Z0.
    M00 (Check tap drill)
    S5000 M03
    M08
  1. Axis motors stop while running a program
    By kevinkoons in forum Mach Mill
    Last Post: 05-22-2007, 07:43 AM
  2. Hass VF6 how do you stop in middle of program
    By SpringKing in forum Haas Mills
    Last Post: 05-14-2007, 04:07 PM
  3. Replies: 2
    Last Post: 06-15-2006, 02:40 PM
  4. program size
    By PTcutter in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-12-2005, 01:43 AM
  5. Stop/start a program
    By jimglass in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-10-2003, 02:59 PM
