Hi, I bought this a while ago to avoid Mach 3 and a PC and it's been working well other than an issue with the probe (I couldn't get it to reset the Y when it touched).
I'm not massively familiar with G-codes etc, I 'get' what they do but I'm a lazy CNC'ist. I mostly use vCarve to generate a file full of the stuff, push it onto a memory stick, plug it in and press go.
So thanks to this thread I found the contact details and obtained a newer version of the firmware (4.0.7 apparently).
I've installed it and set everything up but when I boot I get a "AtuoGM Data ERROR!" box appear (I assume that should read Auto), it then takes me to an AutoGM configuration dialog and at this point I'm stuck.
I've read the bit at https://www.shaogecnc.com/smc5-5-n-n/ on AutoGM but I don't understand it, it sounds like it wants me to create a set of files but containing what?
I don't remember anything about it on the original version (3.7.1).
So before I do a factory reset does anyone have any pointers?
Thanks.
