587,043 active members*
3,155 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > 0i-TC #1202 Parameter help, reset set work coordinates back to G54
    Mar 2018
    8
    Hi guys I just got 2 hwacheon lathes, hi techs. The small one has a 0i-TC controller and when you hit reset it changes the work set back to G54. We need to change it so that the current work set stays modul. I have found that #1201.7 = 0 should do that but it doesn't on both these machines. Also bit 7 isnt labeled WZR like it should be. Is this setting in a different parameter on this controller? All the rest of the Pumas we have in the shop are all set to = 0 and work fine.
    Thanks for nay help
    2932
    Re: 0i-TC #1202 Parameter help, reset set work coordinates back to G54
    The 0iT-C parameter manual I have shows WZR as being bit 7 in parameter #1201, not #1202.
    Mar 2018
    8
    Quote Originally Posted by dcoupar View Post
    Sorry that was my typo. I ment 1201.7
  1. nc studio how to set 'soft' machine coordinates back to zero
    By alceli in forum Commercial CNC Wood Routers
    Last Post: 02-03-2016, 05:47 AM
  2. Work Planes / Work Coordinates
    By MICFDI in forum Esprit
    Last Post: 10-04-2014, 02:41 PM
  3. How do you set your X & Y work coordinates?
    By RicknBeachcrest in forum DIY CNC Router Table Machines
    Last Post: 11-26-2013, 08:51 PM
  4. How to use work coordinates
    By desellers in forum Haas Lathes
    Last Post: 06-24-2013, 02:28 AM
