586,593 active members*
3,121 visitors online*
    Sep 2012
    15
    Changing encoders
    A noob question.
    What changes will be needed if I replace the existing encoder on an old servo motor with either 16 or 20 bit one?
    Do I need to change the servo drive as well? What else should I take into consideration?
    Thank you for much for any input!
    Jun 2011
    692
    Re: Changing encoders
    Need more specifics. If it's an AC servo, you would probably need one that is specifically compatible with the drive. If it's a DC servo, it depends on the drive.
  1. 320X Problem after changing encoders
    By toadjammer in forum Gecko Drives
    Last Post: 02-04-2011, 07:08 AM
  2. cheap absolute encoders? Oxymoron? Decent Incremental encoders?
    By mattbesquare in forum Benchtop Machines
    Last Post: 09-09-2010, 12:56 AM
  3. Encoders
    By seb fontan in forum CNC Machine Related Electronics
    Last Post: 09-27-2005, 09:28 PM
  4. Encoders-to be-or not to be
    By Georgie in forum Stepper Motors / Drives
    Last Post: 02-16-2005, 09:08 PM
