586,570 active members*
3,449 visitors online*
Results 1 to 9 of 9
    Jan 2004
    539
    Alarm / message delete
    My 2012 FM2 got the program corrupted message. I copied and then deleted all of the programs but on start up the message is still there.
    It has done this before with a different message (cant remember)
    How can you get that cleared out?
    Gary
    Mar 2010
    1852
    Re: Alarm / message delete
    Probably a 90000 program. Show them and delete it.
    Jan 2004
    539
    Good call! I think there is one with messed up number (see pic)
    How to edit that, rather than delete?
    Gary
    Mar 2010
    1852
    It will probably not let you edit it, but you could try saving as the correct number then deleting the bad copy.
    Jan 2004
    539
    Wont let me edit or delete or replace by reloading..When I save it and take it to a computer the ! does not show up
    Not sure what the next move would be
    Gary
    Mar 2010
    1852
    Did you disable 90000 program protection?
    Jan 2004
    539
    Settting 23, yes. Could not even see them without it.
    When I try to delete or modify that program I get a 251 Program integrity alarm.
    I did make up a 9000 program and it allows me to load it. The thought being I could cut and past the program guts..and then rename it but I cant get past deleting the original
    Gary
    927
    Gary,
    Most likely , you will to do a delete "ALL" to clear the bad program.
    This entails doing a download of all programs. Either one at time or with the "ALL" function into a single "ALL" file.
    Then deleting all the files with the delete "ALL" function.
    If you do the "ALL" download into one file. Then you will need to use a file editor like word. And delete the lines of the bad program before you reload the "ALL" file back into the control.
    All this sound harder than it is. If you want, let me know and I'll call and walk you thru it. Just PM me on the ONECNC forum.
    Cheers,
    Ward
    Mar 2010
    1852
    My memory is the same, you can't delete one program, you must delete all.
    Mike
  1. Replies: 1
    Last Post: 07-02-2015, 12:20 AM
  2. Alarm message
    By Sigma in forum Uncategorised MetalWorking Machines
    Last Post: 08-14-2008, 12:07 AM
  3. Alarm with no message
    By mr_electrician in forum Fanuc
    Last Post: 06-17-2008, 06:49 PM
  4. Fanuc 11M alarm message
    By Moparmatty in forum DNC Problems and Solutions
    Last Post: 08-07-2007, 03:32 AM
