586,437 active members*
4,127 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Coolant or No Coolant when turning....
    Mar 2007
    215
    Is there ever an instance when flooding coolant can become counter productive when machining a part? Our shop uses mainly Steel, Stainless and Aluminum and
    sometimes Delrin. Any thoughts?
    Oct 2006
    51
    depends on the material, insert and coating. turning steels with a tialn coated insert and coolant can introduce thermal fracturing of the coating.
    kind of like throwing boiling water on a block of ice.
    Mar 2007
    34
    I dont use coolant during interrupted cuts. But always use it for non interrupted cuts. 347 ss, 321 ss, inco, Ti, We use Tialn coated inserts 95% of the time.
    May 2007
    227
    I've never used coolant when using ceramics while turning case hardened chrome.
    The heat is required for the ceramic insert to cut.
  1. Best coolant
    By machinist39 in forum MetalWork Discussion
    Last Post: 06-04-2019, 09:08 PM
  2. Looking for a better coolant?
    By shawn in forum MetalWork Discussion
    Last Post: 06-29-2009, 04:13 PM
  3. Coolant...Which and why?
    By ajl6549 in forum MetalWork Discussion
    Last Post: 12-08-2008, 03:02 PM
  4. programmable coolant
    By pit202 in forum Haas Mills
    Last Post: 12-21-2006, 04:51 PM
  5. COOLANT (what are you using?)
    By carbidecraters in forum MetalWork Discussion
    Last Post: 01-22-2006, 07:31 AM
