586,781 active members*
3,239 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > How to bypass Linear scale in Fanuc Oi-MF controller
Results 1 to 8 of 8
    Feb 2019
    Hi! All,
    I have one drill tap center with Fanuc Oi-MF. All three axis have linear scale and one failed in Y axis.
    I tried to bypass it through 1815#opt but got alarm of SV411 which I avoid by adjust the 1829 parameter.
    Now repeatability is effecting by 15/20 microns.
    Can you please suggest that what I missed ? or what next I need to do?
    Thanks in advance
    Dec 2009
    965
    Re: How to bypass Linear scale in Fanuc Oi-MF controller
    now ,by that 15/20 microns you have the backlash on the ball screw or ballscrew bearings,this backlash was dicovered by your linear scale and if you are bypassing it now ,you use the motor encoder to position and the difference between what encoder see and where the axis is in real time result in a backlash.
    i should start by checking the axial movement of the ballscrew on the ends of it and release and tight again the nut on the end bearings of the ballscrew (opposite to motor side )and check again with a dial if it is still there the 15.20 microns.
    you can also adjust this backlash in parameter 1851 for every axis
    Feb 2019
    7
    which Axis alarm sv410? This axis is a little move to alarm or move a distance and then alarm?
    Feb 2019
    Hi!
    Thanks for your time. there is no backlash and runs fine in 0 rapid. but at 25% rapid, y axis moves a little and it stops with a sudden breaks and SV0411 generates.
    On homing it changes its offset value by 15/20 micron which can't be adjusted in rapid backlash parameter. Local fanuc engineer also clueless.....any idea?
    Dec 2009
    965
    check very good the power connection wires from the motor and from drive
    Jun 2022
    6
    Can you please suggest that what I missed chinese buffets near me
    Thanks in advance
    Dec 2021
    31
    We produce DRO and linear scale, maybe it will help you, you can go to https://www.amazon.com/stores/HHXXOV...2?ref_=ast_bln
    view on
    Or on Whats: +8613528773691
    Contact me at [email protected], [email protected]
    Aug 2018
    44
    You needed to set few parameters ….
    Flexible gear, référence counter, cmr, not so simple….
