586,594 active members*
2,826 visitors online*
    May 2007
    20
    Lapping Compound
    Can anyone recommened a compound for lapping hard bronze to stainless steel? When selecting a lapping compound should one use a producted with respect to the harder surface?
    Any lapping theroy is appreciated.
    Nov 2005
    1468
    I've been grinding metals and glass for more than half my life and prefer the loose abrasives (aloxite) with water than the diamond abrasives, but others prefer the diamond products check these sites (I have no commercial contact with any of these)
    http://www.engis.com/
    The loose Aloxite powder grade I use is graded at 302, 302 1/2 and 303 for finishing, just got back to work from a customer and leaving in 10 mins, will post more tomorrow.
    It all really depends on how much material you want to remove- you need to work down from rough to finishing grades on either choice.
    The oil based diamond products are a pain to clean off and tend to "clog", although others may say that the diamond products remove more material, I find that for total control of surface profile the Aloxite and water is better.
    Post more tomorrow.
    I love deadlines- I like the whooshing sound they make as they fly by.
    Apr 2006
    3206
    WD40 to the Rescue!!
    There's few things I'd recommend WD40 for, but lapping is something that it seems to be very well suited to.
    There's a lot of times when I'll duct tape a sheet of abrasive to the surface plate, squirt some WD40 on it, and flat-lap a part. What I like is that the paper doesn't tend to load up, and its easy to clean. It tends to act like a beautiful cross between water and oil.
  1. Lapping the Ways on my x2, Help!
    By FroggyOne2 in forum Benchtop Machines
    Last Post: 05-04-2007, 08:03 PM
  2. Enco Compound Slide Milling & Compound Drilling Table
    By 7ofclubs in forum DIY CNC Router Table Machines
    Last Post: 12-24-2006, 05:43 AM
  3. Stupid question. what is lapping and how is it done?
    By triump in forum Charter Oak Automation Support Forum
    Last Post: 11-01-2006, 10:21 PM
  4. Q: X3 Cleanup/Lapping/Setup
    By Deviant in forum Benchtop Machines
    Last Post: 09-04-2006, 02:40 AM
  5. Help with shipping IH lapping kit to Canada
    By ngr1 in forum Charter Oak Automation Support Forum
    Last Post: 08-30-2006, 12:28 AM
