586,797 active members*
3,459 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > pls, how to check if there are free M codes ?
    Jun 2015
    4156
    hello, pls, how to check if there are free M codes, on genos l3000 ?
    should i be looking for something inside the electrical cabinet, on the controller, etc ? kindly
    Code:
    ccdrps-pv1.35                    - 5/10 - <W01><O01><        L3000-EE><P574205>
    ===========================[ NC-SPEC CODE No.1 ]==============================
    1100-0100-4101-0000-14C0-0F18-1300-1043
    0001-9DD2-2980-0100-0111-6000-1041-0002
    SLANT-Y AXIS     -  ONE TOUCH IGF ADVo  EXTERNAL MEASURE -  TOOL CENTER CTRL -
    Y AXIS BY CT-Z   -  TAPE DATA IN/OUT o  MEASURE RS232C   -  Hi-Cut Pro       o
                     -  FD IN/OUT(IBM)   -  CEJ MATIC        -  SUPER-NURBS Hi.  -
    Y-AXIS BARRIER   -  WITHOUT MS-DOS   -  SIZE CATCHER     -  NURBS            -
    Y HORI.BARRIER   -  T-SEPARATE EDIT  -  EX.MEASURE BCD   -  SUPER Hi-NC      -
    B-AXIS 0.001‹   -  DNC-C ETHERNET   -  T-SETTER R/L COM -  SUPER-NURBS Rac. -
    B-AXIS 1‹PITCH  -  P-200 SPEC       o                   -  TOOL-ID          -
    B-AXIS CONTROL   -  FL-net           -                   -  Inverse Time Feed-
    ATC              -  BUFFER 160M      -  TOUCH SETTER     o  ST. REST ZB      -
    1CAM-ATC         -  BUFFER 320M      -  2ND SP MEASURE   -  ST. REST MID     -
    2CAM-ATC         -  BUFFER 640M      -  TOUCH SETTER AUTO-  ST. REST ZC      -
    EXT.ATC HOME POS -  BUFFER 1280M     -  TOUCH SENSOR     -                   -
    VTM MACHINE      -  NO-SSU-RD        o  C ZERO OFFSET    -  ST.R TOW-A.B     -
    NEW MG.PANEL     -  FDD3.5INCH EDIT  -  Y GAUGING        -  ST.R TOW-A.AUTO  -
    PANEL OLD TYPE   -  EDIT INTERLOCK   -  OPTICAL SENSOR   -  ST.R TOW-A.JOG   -
    Y-AXIS TRQUE LIM.-  EDIT INTERLOCK C -  MEASU.DATA PRT.  -  ST. REST TOW-A.  -
    HI-G CONTROL     o  PROGRAM SELECT   -                   -  CE MARKING       o
    PFC‡U            -  MG TOOL READY    -                   -                   -
    B-AXIS COMP.     -  COMMON VAR. NAME -                   -  NC DOOR          -
    X-AXIS COMP.     -  HOME POSITION B  -                   -  SPEC. SELECT     -
    WK.CORDINATE 10  -  WARMING UP       -                   -  R SPEC           -
    WK.CORDINATE 50  -  MACHINE LOCK SP. -                   -                   -
    TOOL OFFSET 500  -  G00 LINEAR FEED  -  ABSO SCALE CA    -  THERMAL COMP. L2 o
    TOOL LIFE WARN.  -  A/B SYNC. MOTION -                   o  THERMAL COMP. L1 -
    NC TURRET        o  PLANE CONVERSION o  TURRET POS.COMP. o  NC MASTER        -
    OTC TURRET       -  PROFILE GENERAT. o  TOOL OFFSET 64   -  S-LINK NC TEST   -
    CAM TURRET       -  CONTOUR CUTTING. -  TOOL OFFSET 96   -  S-LINK SP TEST   -
    MANY CHIPS TOOL  -  B-AXIS INTERPOL. -  TOOL LIFE MNGMNT o  OH               -
    ABSO SCALE TA    -  SYNCHRO.TAPPING  o  TOOL OFFSET 200  -  NEW OPERAT.PANEL o
    B-AXIS TURRET    -  FLAT TURNING     -  TOOL WEAR COMP.  o  NO SERVO         -
    HEAVY TOOLING    o  HELICAL CUTTING  -  TOOL OFFSET SYS. -  PLC/SFC PROGRAM  -
    DOUBLE TOOLING   -  SLANT CUTTING    -  TOOL OFFSET 800  -  PLC              -
    LT MACHINE       -  HOME POSITION    -                   -  NC ROBOT         -
    SUB SPINDLE      -  SPINDLE SYNC.TAP -  I/M SWICTH       o  NC LOADER        -
    PARALLEL 2 SPNDL -  TOOL RETRACTION  -  SCRIPT FUNCTION  -  SYSTEM STAT.DISP -
    PICK OFF UNIT    -  SPIN. FLUCTUATE  o  WINDOWS OPERATION-  OH LOGO CHANGE   -
    VERTICAL MACHINE -  NC TORQUE LIMIT. o  CYCLE TIME CAL.  o  C-AXIS COMP. 2   -
    LAW-V MACHINE    -  THREAD OVERRIDE  -  CYCLE TIME REDUC -  F CONVERT        -
    ACC MACHINE      -  GM CODE MCRO     -  CYCLE TIME R.NEW o  LOST MOTION CMP. -
    B-TURRET SUB SP. -  CENTER COMP.     -  NO LOAD DETECT   o  PLR2 LOW SEQUENCE-
    MULTIPLE MACHINE o  LAP4             o  NC WORK COUNTER  o  PROG. TAIL STOCK -
    B-TURRET M-AXIS  -  NOSE-R 2B        o  WORK CNT.SPECIAL -  SIMPLE TOW-ALONG -
    M-AXIS NO C-AX.  -  USER TASK 2      o  NC WORK MONITOR  o  PG. TAIL STOCK B -
    T/M AXIS SW.     -  EXP.AUTO CHAMF   o  CYCLE TIME CHECK o  AUTO TAIL STOCK  -
    L TOOL INDEX     -  THREAD PNT.OFFST -  LOAD MONITOR     o  TAIL STOCK CLUMP -
                     -  THREAD FEED HOLD -  LOAD MONITOR W   -  NC TAIL STOCK    o
    MULTI-MAGAZINE   -  ARC THREAD CUT.  -  MAC MAN COMM.    -  NC TAIL STOCK TRQo
    SYNCHRO. REVERSE -  COMMON VAR. 1000 -  MAC MAN          o  MANY CHIPS 12    -
    2 SADDLE MACHINE -  ONE TOUCH IGF    -  DNC-T1           o  SPINDLE ORIENT.  o
    MIRROR IMAGE     -  IGF              -  DNC-T2           -  MANY CHIPS 4     -
    Z-W OVER LAP     -  IGF CONVERT      -  DNC-T3           -  CB-AX. WO MB-AX. -
    CAM MACHINE      -  IGF DATA TRANS   -  DNC-T4           -  C SYNC. CONTROL  -
    NEW W-DATA       -  ONE-TOUCH S/SHEET-  DNC-P1           -  M-AXIS ORIENT.   o
    SUB MAGAZINE     -  COL.AVOID.SYSTEM -  DNC-P2           -  L MULTIPLE MACHIN-
    H1 TURRET        -  PROGRAMING HELP  o  DNC-P3           -  R MULTIPLE MACHIN-
    FLAT BED         -  HELP             o  DNC-P4           -  HOB CUTTING      -
    SERVO LINK NC    o  STN L.C.D MONO.  -  DNC-A            -  SPINDLE MAX IL.  o
                     -  E100 SPEC.       -  DNC-B            -  SP-HEAD IL.      -
    0 OFFSET DETECT  -  3D. ANIMATION    o  DNC-C1           -  PARTS CA. IL.    -
                     -  ACP EXPANSION    -  DNC-C2           -  1S PARTS CA. IL. -
    SERVO LINK SPNDL o  ANIMATION        o  DNC-C3           -  ZA-W AXIS IL.    -
    SPINDLE ANALOG   -  S10 SPEC.        -  DNC-DT           -  XB-W AXIS IL.    -
    SPINDLE I/O      -  U100/U10 SPEC.   -  SMPL.REMOTE DIAG -  TURRET ZA-W IL.  -
                     -  OAC MESSAGE      -  DNC-RT           -  TAIL-ST.REST IL. -
    ccdrps-pv1.35                    - 6/10 - <W01><O01><        L3000-EE><P574205>
    ===========================[ NC-B SPEC CODE No.1 ]============================
    0040-A300-0000-C010-3005-5100-0000-0000
    0000-0380-0000-0000-A000-6D00-A000-0000
    COORDINATE CONV. -  ATTACHMENT       -  A-TRT MID. POS.  -  CAM-AXIS ICB     -
    WK.CORDINATE 100 -  ATTACHMENT SWIVEL-  B-TRT MID. POS.  -  CAM LE. LESS     -
    TOOL OFFSET 999  -  MLT MAG. TYPE-C  -  C-TRT MID. POS.  -                   -
    CORDINATE CAL    -  VTR              -  CAS HYDRAULIC TRT-                   -
    PROGRAM MESSAGE  o  LONG BORING BAR B-                   -                   -
    3-D CO. CONV.    -  3-D CO. CONV. 2  -  LATHE X-RADIUS   -                   -
    PROF.GENE.HELI.  -  3-D INDEX        -  OP. BUFFER EXPAND-                   -
    PREMIUM THREAD   -  L TOOL INDEX SP. -  MULTI TOOL       -  EtherNet/IP      -
    NC TST HI PRECISE-  MEAS.DATA COMM.SP-  HI-SPEED RESTART -                   -
    NC TST POLS LOW  -  3 AXIS MEASURE   -  L-G IGF LINK     -                   -
    NC TST CHECK LESS-  M-AXIS MEASURE   -  BLOCK SKIP MULT. -                   -
    TST 1ST-SP ATT.  -  M-AXIS INTERPOL. -  M-GUIDANCE 2     -                   -
    W AXIS CUTTING   -  BLUM HYBRID SEN. -  T-GUIDANCE(MAIN) -                   -
                     -                   -  T-GUIDANCE(SUB)  -                   -
    NC TST 1st INCH  o                   -                   -                   -
    NC TST INCH      o                   -                   -                   -
    APC              -  TOUCH SETTER2    -  ABCO SCALE YSB   -                   -
    NC UNLOADER      -  STROKE LIMIT RLS -  ABSO SCALE YSC   -                   -
    WORK SUPPORT     -  RIGID TOUCH SETR -  ABSO SCALE XC    -                   -
    MULT.U MATRIX MG -  Y-MODE TOUCH SETR-  ABSO SCALE ZC    -                   -
    L TOOL IDX. SEL  -  TL BRAK. DETECT. -                   -                   -
    MLT MAG. TYPE-B  -  AE SENSOR        -                   -                   -
    ATC.EX.HP        -  BLUM SENSOR      -                   -                   -
    POT TOOL TABLE   -  STROKE DIVIDE    -                   -                   -
    MG-AXIS ATC      -  PLC CROSS RAIL   -  B-TRT Y-AXIS     -  STATUS LOGGER    -
    C-AXIS 1POINT    -  NC CROSS RAIL    -                   -  STATUS MONITOR   -
    RT-AXIS ATC      -  HP CROSS RAIL    -  ZA-ZC AXIS IL    -  RETRACT(ST.MON.) -
                     -                   -                   -  ADD. SENSOR      -
    TR. ATC TYPE-A   -                   -  3 SADDLE MACHINE -                   -
    TR. ATC TYPE-B   -                   -  C-TRT M-AXIS     -  GATHER AGING     o
    TR. ATC TYPE-C   -                   -  C-TRT SUB SPNDLE -                   -
    TURRET ATC       -                   -  C-TRT Y-AXIS     -  MACHINE DIAG.    o
    CUSTOM-API       -  TOOL DIRECTION   -  SA AXIS TANDEM   -  2M1L ONE SIDE CUT-
    OSP-API          -  TOOL DIR COMP.   -  SB AXIS TANDEM   -                   -
    USER TASK 3      -  TCPC MACHINE CO. -  SPINDLE ACCEL SET-                   -
    THiNC ALARM      -  TCPC CUT POINT   -  SPINDLE ROT. 0.1 -                   -
    M-INTELLIGENCE   -  TCPC SUB SPINDLE -  STEP CUTTING FEED-                   -
    M-SPN. FLUCTUATE -  TCPC LATHE TURN. -  C-AXIS CLAMP AUT.-                   -
    L-GUIDANCE       -  B/C TURRET TRIC  -  TOOL GROOVE PROC.-                   -
    M-GUIDANCE       -  SUPER PROF. GENE.-  SP.COL. DETECTIONo                   -
    USE TOOL DISP.   o  AXIS ACTIVE STOP o  CE MARKING STOP  o  EASY OPERAT PANELo
    MACHINING MODE   o  M-AX LIFE COUNT  -  MFU              o  MULT OPERAT PANEL-
    NOSE-R DIR CHG   -  0.1u TB/MB AX. SP-  GEOMETRIC COMP.  -  L TOOL MAC INFORMo
    INTERRUPT PROGRAM-  STRAIGHT. COMP.  -  GEOMETRIC MES.   -  EOP ANM SCALE-UP o
    INTERRUPT PROG2  -  VAR. LOST MOTION o                   -  19 INCH EXTEND   -
    BASE OP. SCREEN  o  SERVO NAVI L     -                   -  ECO SUITE        o
    TOOL MAC INFORM. -  RPD FD SPEED SET o  M-AXIS TORQ. SKIP-  OSP SUITE        o
    OFFSET BASE FIX  o  TIME CONST SELECT-  TURNING CUT      -  BASEZERO Z V.MEAS-
    SERVO ADJUST SP  -  WORK WEIGHT SET  o  SELF ST.R 1      -  POWER METER      -
    TOOL LIFE NOT.SP -  Y-AX MANUAL FEED -  SELF ST.R 2      -  TH.COMP.OILCON   -
    WORK ROUGH       -  C-AXIS MANUAL CO.o  SELF ST.R 3      -                   -
    ST.REST BARRIER  -  C-AXIS TORQ. SKIP-  SELF ST.R 1 REL. -                   -
    WORK POSITION 30 -  HOME POSITION C  -  SELF ST.R 2 REL. -                   -
    NO HIGH LOW TH.  -  AT ROTATION COMP -  SELF ST.R 3 REL. -                   -
    TORQUE WATCH     o  LONG BORING BAR  -                   -                   -
    TAILSTOCK SP.LOW -  TOOL BASE        -                   -                   -
    TOOL LIFE NOTICE -  SYNC.CONTROL ZA  -  BELT SLIP CHECK  -  MAC. TIME SHORT. -
    GOT-HMI          -  SYNC.CONTROL XA  -  M BELT SLIP CHECK-                   -
    MEASU.COMP.CLEAR -                   -                   -                   -
    ALARM MESSAGE    -                   -                   -                   -
    OTHER.SYS.WATCH  -  SDF SEPARATE NC  o  GEN. OL. DETECT  -                   -
    CON BACK SP      -  SDF SEPARATE SP  o  NO LOAD DET. EXT -  SPIN. OUT. MON.  o
    0.1u T/M AXIS SP.-  SDF SEPARATE PLC -  LOAD MONITOR EXT -  SUITE w/o WIDGET -
    LOST MOTION CMP. -  FEED AXIS RETRACT-  C-AX NOTCH FILTER-  REMAI.TIME DISP. o
    ccdrps-pv1.35                    - 7/10 - <W01><O01><        L3000-EE><P574205>
    ===========================[ PLC-SPEC CODE No.1 ]=============================
    0200-0210-0000-0100-0100-0012-0001-0100
    0000-0020-4004-0012-0000-0000-1040-0000
    ST. REST FIX     -  HIGH COOLANT     -  OVERRIDE SPECIAL -  L TOOL INDEX SP  -
    ST. REST MID     -  B-TURRET 1MMTR   -  LOAD MONITOR     o  TL EXST COMF.REV.-
    ST. REST LOW-T   -  A-COOLANT 1MMTR  -  SAFETY TAPE SW   -                   -
    ST. REST REL.    -  COOLANT H/L SP.  -  NC MASTER        -  FL-net           -
    ST. REST OPEN    -  CLNT LEVEL CHECK -  CYCLE TIME RE.NEWo                   -
    ST. REST CLOSE   -  CLNT FLOW CHECK  -  LAW-F L-MACHINE  -                   -
    ST. REST TOW-A   -  COOLANT L/M CHG. -  PNL.POSIT. FRONT -                   -
    ST. REST GR.COMF -  CLNT.THRU.SPNDL. -  T CONST SWITCH   -                   -
    CENTER WORK      o  M-AXIS ORIENT.   o  DNC-B            -  B-AXIS TURRET    -
    TAIL STOCK LIMIT -  FLAT TURNING     -  DNC-C            -  B-AXIS 1‹PITCH  -
    TAIL-STK.IL.RLS. -  B-TURRET M-AXIS  -  ATC TYPE G       -  B-AXIS 0.001‹   -
    PROG. TAIL STOCK -  B-AXIS POS LOMP  -  W-AXIS OVERLAP   -  TURRET TYPE-H1   -
    SIMPLE TOW-ALONG -  ATC TYPE H       -  ST.R AUTO TOW-A B-  TURRET TYPE-H2   -
    TAIL STK.RT.INCH -  CAM AXIS LUB.    -  THREAD OVERRIDE  -  TR.PNDLM.CNTRL.  -
    ST.R AUTO TOW-A. -  M-AXIS OIL MIST  -  IND.CHK1 NO CHECK-  L TOOL INDEX     -
    ST. R. ENABLE SW -  M-SP. OILCOOLER  -  PROG. TAIL STK. B-  L TOOL THD. CLMP -
    CHUCK GRASP COMF -  TOUCH SETTER     o  WARMING UP       -  NO CEIL 2        -
    CHUCK IL. RLS.   -  TOUCH SET. SLIDE -  WORK CNT.SPECIAL -  NO CEIL 3        -
    CHUCK. MISS 1 SP -  TOUCH SET. COVER -  CHIP CNVYR CHECK o  WORK STOCKER     -
    CHUCK. MISS 2 SP -  TOUCH SET. MOTOR -  THRU&MEASURE AIR -  WORK STOCKER2    -
    CHUCK H/L 1 SP.  -  TL BRAK. DETECT. -  DRAIN PUMP       -  VERTICAL SW. LO. -
    CHUCK H/L 2 SP.  -  WORK EJECTOR     -  SP AIR PURGE DET -  T.CLMP OUTPUT HLD-
    INDEX CHK 45 1SP -  WORK EJ.AD CONF  -  AIR PRES.DETECT  -  B-PANEL          o
    INDEX CHK 90 1SP -  WORK EJ.RT CONF  -  SEQUENCER ALARM  -  NC DOOR          -
    2 CHUCK PDL. 1SP -  EXTERNAL MEASURE -  DUAL START       -  NC ROBOT         -
    SMW CHUCK 1 SP.  -  EX. MEASURE BCD  -  DUAL ST.DR. CLS. -  OR5              -
    FR.DRV.CHUCK 1SP -  CEJ MATIC        -  EDIT INTERLOCK   -  HYD ER DET.      -
    CHK GRSP SPC 1SP -  TOUCH SENSOR 2SP -  PROG.STOP SPECIA -  SPEC SELECT      -
    2 CHUCK PDL. 2SP -  TOUCH SENSOR     -  PANEL POSIT. SP  -  NO CE DOOR OPENLSo
    SMW CHUCK 2SP    -  OPTICAL SENSOR   -  PORTABLE PH      -  OSP CHIP CONVERE -
    FR.DRV.CHUCK 2SP -  2SP TOUCH SETTER -  CE MARKING       o  SWING&LIMIT SWIVE-
    CHK GRSP SPC 2SP -  TOUCH SET. COV.LK-  OIL LEVEL DETECT -  OR SEFTY FENCE   -
    HYD. UNIT COOLER -  MECHA-LOCK DOOR1 -  BF/PC BIT SWITCH -  A CLAMP MISS CHK -
    OIL COOLER ALM-A -  MECHA-LOCK DOOR2 o  PARTS CATCHER    -  B CLAMP MISS CHK -
    HYD. OIL COOLER  -  R.DOOR2          -  PARTS CA.DOOR IL -  SWING IL TYPE-A  -
    WITHOUT STE SW   -  AUTO DOOR2       -  PARTS CA.AD/RT SP-  SWING IL TYPE-B  -
    EX BRAKE RELEASE o  DOOR IL. S       o  PARTS CA.SWING   -  DUAL HAND OPE.   -
    SAFETY RELAY     -  DOOR IL. D       -  NC TAIL STOCK    o  FENCE MECHA-LOCK -
    POS UNIT         -  DOOR IL. E       -  CONV.DEVICE I/F  -  HAND OPE. I.L.   -
    CHUCK IL.RLS.SP  -  MECHA-LOCK SP.   -  UNLOADER  I/F    -  LDR AXIS INTRLCK -
    SPNDL OIL AIR LUB-  DR.SPEED SWITCH  -  BAR FEEDER I/F 1 -  NC LOADER        -
    SPNDL ORNT.ELEC. o  AUTO DOOR        -  BAR FEEDER I/F 2 -  NC LOADER TYPE-C -
    SPNDL ORNT. PIN  -  DOOR CONTROL     -  B.FEEDER CHK.IL. -  2M1L             -
    SPNDL ORNT. BRK. -  R.DOOR ONE BODY  -  BAR FEEDER I/F 3 -  3M1L             -
    1SP. LOWEST SP.  -  R.DOOR SIDE OPEN -  BAR FEEDER I/F 4 -  GANTRY LOADER    -
    2SP. LOWEST SP.  -  ROOF DOOR        -  BAR FEEDER I/F 5 -  RECIPROCAL INTER -
    1SP. OIL COOLER  -  PL DOOR I.L.E-D  -  THRU. AIRBLOW IL.-  2CARRIERS LDR    -
    2SP. OIL COOLER  -  PL DOOR I.L.E-C  -  CUT OFF DETECT   -  3 AXIS LOADER    -
                     -  ATC TYPE A       -  RBT/LDR I/F B    -  TURNOVER DEVICE  -
    FLAT BED         -  ATC TYPE B       -  RBT/LDR I/F C    -  TRNOVR RTRCT SP. -
    W-AXIS CONTROL   -  ATC TYPE C       -  RBT/LDR I/F D    -  TURNOVER L->R    -
    HYD LESS         -  ATC TYPE D       -  OGL LOADER I/F   -  DIREC SWITCHABLE -
    W-AXIS CLAMP     -  MG. DOOR 2       -  PROGRAM SELECT A -  MULTI-MAGAZINE   -
    HOB CUTTING      -  MG.DOOR MECHA-LK -  PROGRAM SELECT B -  M.LOCK SP CVR.   -
    B-TURRET SUB SP. -  MG TOOL MAN CHG  -  PROGRAM SELECT C -  LVT SAFETY FENCE -
    B-AXIS INTERPOL. -  TOOL ID          -  FIX POT ATC      -  MEASURE OVER M/C -
    2 SADDLE MACHINE -  NC TURRET        o  LFS10            -  FINGER CHUCK 4-1 -
    MULTIPLE MACHINE o  TURRET LIMIT A   -  LVT              -  FINGER CHUCK 4-2 -
    OPPOSED TURRET   -  CAM TURRET       -  LAW-V            -  FINGER CHUCK 2-1 -
    SUB SPINDLE      -  NC TR WITH BRAKE -  2SP-H            -  FINGER CHUCK 2-2 -
    OPPOSED 2 SPNDL  -  TURRET LIMIT B   -  ACC MACHINE      -  COLLET GRSP COMF -
    SLANT-Y AXIS     -  1MMT CLUTCH COMF.-  ATC TYPE-E       -  SIDE COVER I.L.  -
    PARALLEL 2 SPNDL -  1 MOTOR MULTI TR -  ATC TYPE-F       -  M.LOCK SIDE CVR. -
    B-AXIS TURRET    -  1MMT BRAKE CR    -  SUB MAGAZINE     -  SUB PANEL        -
    ccdrps-pv1.35                    - 8/10 - <W01><O01><        L3000-EE><P574205>
    ===========================[ PLC-SPEC CODE No.2 ]===========================
    0100-0008-0100-0000-0000-0000-0000-0000
    0000-0001-0010-0000-0000-0000-0088-0000
    HP COOLANT UNIT  -  1SP C BRAKE KEEP -  MAN JOG FEED     -                   -
    HP COOLANT UNIT2 -  2SP C BRAKE KEEP -  SP COM. UNIT 0.1 -                   -
    HP COOLANT UNIT3 -  FD.CHUCK 1 GRSP  -  CHIP NIPPING AVO.-                   -
    RV. FLUSH CLNT   -  FD.CHUCK GRSP.CK -  CAT TOOL DIR.    -                   -
    BL. SADDLE CLNT  -  C UNCLAMP CONF.  -  TABLE ROUND CONV.-                   -
    ANOTHER TANK     -  1SP A.CHUCK RSS  -  MG CLAMP         -                   -
    RV. FLUSH CLNT2  -  2SP A.CHUCK RSS  -  SETUP MODE       -                   -
    SP TAIL WORK HLD -  NC ST. R. CLAMP  -  GEN. OL. DETECT  -  PREVENT TS. RT.  -
    SAFETY SW RST    -  OPTICAL SENSOR B -  RIGID TURRET     -  SIDE SHUTTER     -
    DOOR DIVISION    -  TOUCH SET.SLD B  -  A-TURRET PENDULUM-  TCH STTR POS RV  -
    FLAT DOOR IL     -  TOUCH SET.CROS-L -  B-TURRET PENDULUM-  1SP CHK GRASP C  -
    FLAT 1 DOOR      -  TOUCH SET.CROS-R1-  A-TURRET PND. SW.-  2SP CHK GRASP C  -
    FLAT DOOR IL SP  -  TOUCH SET.CROS-R2-  B-TURRET PND. SW.-  W-AXIS CUTTING   -
    FLAT DOOR MLK    -  TOUCH SET.SLID R -  DOOR IL. SW CHECK-  TOUCH SET.TRN.SLD-
    R.DR.GUIDE SLIDE -  TR.&MEASURE AIR  -  OSP CNVYR PNL.SP -  DOOR I.L.E-C SP  -
    MAINTE DOOR      -  T SETTER MOTOR B -  SPNDL LUBE DRAIN -  SP. LATHE TOOL   -
    NC STEADY REST   -  SCHUNK CHUCK 1 SP-  ACC AREA SENSOR  -  MCTYPE VTR-A     -
    ST REST AIR CLAMP-  SCHUNK CHUCK 2 SP-  SP VIB. SENSOR   -  ANGLE HEAD       -
    SELF ST.R 1      -  CHUCK H/L B 1SP. -  S-ST CHK. PDL/PB -  L-NAVI GUIDANCE  -
    SELF ST.R 2      -  P-TS UNCLAMP IL  -  APC SPNDL CLAMP  -  EASY OPERAT PANELo
    SELF ST.R 3      -  HP COOLANT UNIT5 -  PH TYPE-B        o  ANG COOLANT      -
    SELF ST.R 1 REL. -  HP COOLANT UNIT6 -  C CONNECT SP     -  ANG AIRBLOW      -
    SELF ST.R 2 REL. -  VTR CHUCK CTRL   -  PH TYPE-C        -  SHOWER SW        -
    SELF ST.R 3 REL. -  2APC SETUP CLAMP -  THINC ALARM      -  MF UNIT          o
    NC TAIL WORK HLD o  HAND PUSH. AIR   -  2PALLET APC      -  ATC TYPE-P       -
    NC TAIL NO CHG   -  STOCKER INV.CTRL -  STACKER CRANE I/F-  ATC NO MOD RST   -
    NC TAIL NO PEDAL -  STCK.AREA SENSOR -  C AXIS GROUP SW. -  DOOR WINDOW      -
    HYD QL NC TAIL   -  3AX LDR SWING IL -  PALLET CLAMP B   -  DRUM FILTER      -
    NC TAIL PRECISE  -  CHUCK H/L B 2SP. -  2PALLET APC I/F C-  PH ENABLE SW     -
    NC TAIL POLS LOW -  1SP C GAIN CUT   -  6PALLET APC I/F C-  ATC SIDE TH.TOOL -
    TAIL SLEEVE I.L  -  2SP C GAIN CUT   -  APC DOOR         -  ST.REST MAN GRIP -
    TAIL SLEEVE 1SP  -  NC UNLOADER      -  PALLET CLAMP C   -  3 SADDLE MACHINE -
    CHUCK GRASP CO.B1-  SUB PNL.B ST.CHG -  NEW CEMK         o  AIR NOZZLE SW    -
    CHUCK GRASP CO.B2-  CENT.PARTITION   -  M-NAVI GUIDANCE  -  M-SP AIRBLOW SW  -
    ST. REST ZC      -  SP PEAK POW. CUT -  SUB PNL.B BIT SW -  CHIP CON SW      -
    NC TAIL INCHING  o  CE CHUCK NO CONF -  ATC OIL PRES.DET -  OILMIST SW       -
    INDEX CHK 45/90SW-  ATC TYPE-Q       -  OIL LEVEL DET.2  -  OILHOLE SW       -
    2SP CHK DS SENSOR-  MULTI-MAG. B     -  VERT. MLT. PANEL -  OILHOLE HIGH SW  -
    CHUCK GRASP CO.D1-  APC FRONT DOOR2  -  OPERATION DOOR   -  COOLANT CLOG     -
    CHUCK GRASP CO.D2-  CHUCK/JIG CHANGE -  C CLAMP CONF.    -  COOLANT LV CHECK -
    SP. LOW. FIX. SP.-  A TURRET MID.    -  PWR SUP R/L COM  -  M-SP COOLING     -
    C AXS BR. TRQ LMT-  B TURRET MID.    -  EX CUT FEED OVR  -  THR SP COOLANT   -
    SKIVING CUT      -  C TURRET MID.    -  EX INT PROGRAM   -  X-AXIS OILMIST   -
    TURN.TOOL GROOVE -  2APC I/F B       -  SUB PANEL B      -  OIL SKIMMER      -
    1SP WIND-CHG SP  -  L TOOL IDX. SEL  -  EX NC FEED HOLD  -  COOLANT COOLING  -
    2SP WIND-CHG SP  -  B 2MMTR TYPE B   -  INSIDE M/C CNVYR -  COOLANT SW       -
    SP BRAKE PS      -  C MODE C BRAKE   -  LIST UP MOSNIC A -  WORK WASH SW     -
    MAN MODE C BRAKE -  TAIL STOCK CLAMP -  LIST UP MOSNIC B -  CHIP FLUSH SW    -
    MANY CHIPS 12    -  M-SP LUBE CHECK  -  HP COOLANT UNIT4 -  AAC              -
    MANY CHIPS 8     -  M-SP OIL AIR     -  AXIS RETRACT     -  M-SP CL/UC MCODE -
    ATC POS INDEX RE -  MA-SP. LOWEST    -  CROSS RAIL AUTO 7-  AT MCODE         -
    B-AXIS 5deg PITCH-  M-SP 4P INDEX    -  CROSS RAIL AUTO 8-  AT-C INDEX 5DEG  -
    MANY CHIPS 4     -  TOOL M-SP.MAX    -  CROSS RAIL AUTO 9-  MAN AT TOOL CHG  -
    TL EXIST COMF.   -  C-TURRET M-AXIS  -  CROSS RAIL AUTO10-  AAC TYPE B       -
    TURNING IL       -  CHIP BITING AV.  -  DOOR IL S SP     -  DOOR IL S SP2    -
    2MOTOR TR TYPE B -  Machin. Navi M-i -  PENDANT IL       -  CONVEYER HOLD DR -
    2MOTOR MULTI TR  o  LINEAR GUIDE CVR.-  FIRE ALARM CHK   -  ATC TYPE M       -
    2MOTOR TR B      -  ATC CYCL TIME RE -  MIST COLLECTOR   -  ATC SHUTTER      -
    TR INDEX COND W  -  ATC TYPE I       -  0.1UM PH CHG     -  MATRIX TIM.RE.A  -
    2SP-H TR.CLMP-R  -  EX ATC HP        -  CROSS RAIL AUTO  -  MATRIX TIM.RE.B  -
    2SP-H TR.CLMP-L  -  ATC TYPE J       -  CROSS RAIL AT-C  -  ATC COV.TOOL     -
    B TURRET Y       -  ATC TYPE K       -  SP ER DET. SHARE -  ATC LATHE TOOL   -
    C TURRET Y       -  TOOL RET MT CM   -  ABSO SCALE FILT. -  ATC TYPE N       -
    2 MOTOR TR C     -  ATC TYPE L       -  1SP INDEX CHK SP -  ATC SENS. TOOL   -
    ccdrps-pv1.35                    - 9/10 - <W01><O01><        L3000-EE><P574205>
    ===========================[ PLC-SPEC CODE No.3 ]===========================
    0100-0000-2000-0000-0000-0000-0000-0000
    0000-0000-0000-0000-0000-0000-0000-0000
    TH./ATC AIR COM. -                   -                   -                   -
    A L-TUR. ATC     -                   -                   -                   -
    B L-TUR. ATC     -                   -                   -                   -
    ST.R GR.COMF C   -                   -                   -                   -
    PROG TS AIR CLP  -                   -                   -                   -
    CUT STATUS MON.  -                   -                   -                   -
    SP.DIAGNOSTIC    o                   -                   -                   -
    ATC TYPE-S       -                   -                   -                   -
    ENABLE SW CHECK  -                   -                   -                   -
    BLUM TOUCH PROBE -                   -                   -                   -
    TR BRAK. DETECT.C-                   -                   -                   -
    HYBRID SENSOR    -                   -                   -                   -
    ST.R. MOUNT PAR. -                   -                   -                   -
    TAIL ADVANCE 2   -                   -                   -                   -
    PARTS CA. BELT   -                   -                   -                   -
    OIL CNLT SPECIAL -                   -                   -                   -
    OSP suite        -                   -                   -                   -
    TURNING CUT      -                   -                   -                   -
    Work Supp.B-Tur. -                   -                   -                   -
    NC UNLOADER B    -                   -                   -                   -
    WORK EJECT H1    -                   -                   -                   -
    CE PARTS CA.DRIL -                   -                   -                   -
    BALL SCREW COOL. -                   -                   -                   -
    DATA TRA. OUT.MG -                   -                   -                   -
    VL L-MACHINE     -                   -                   -                   -
    WORK SUPPORT SP. -                   -                   -                   -
    HP COOLANT UNIT7 -                   -                   -                   -
    TOOL IC          -                   -                   -                   -
    ST.R GR.COMF B   -                   -                   -                   -
    TL BRAK. DETECT.B-                   -                   -                   -
    THRM. OIL COOLER -                   -                   -                   -
    DOOR INCHING     -                   -                   -                   -
    CHIP CNV.INTERV. -                   -                   -                   -
    ECO SUITE        o                   -                   -                   -
    M-AXIS INTERPOL. -                   -                   -                   -
    M-AXIS MEASURE   -                   -                   -                   -
    M-AXIS CLAMP M   -                   -                   -                   -
    MATRIX TLS SHUT. -                   -                   -                   -
    ATC-H MATRIX MG  -                   -                   -                   -
    C-AXIS CLAMP AUT -                   -                   -                   -
    NC TAIL START IL -                   -                   -                   -
    Aug 2011
    420
    Re: pls, how to check if there are free M codes ?
    What is the " Y AXIS BY CT-Z " option
    "Imagination is more important than knowledge."
    Jul 2010
    287
    If by "free" you mean "spare" then I don't know if that shows up on the data management card anywhere.
    You can try to look for the I/O's for them and see if they're labeled as L or not.
    If they are logical then there is no spare M code. I'm not sure what country you're in, but in the US, you're looking for oUSM1 or iUSM1A (M101) for the answer (up to 108 or something in the 2or300's but they always give you M101-whatever first).
    If you're looking for physical wiring, you're looking for something that looks like this:
    Jun 2015
    4156
    hy, a while ago i was interested into checking those, for adding some auto-doors and 2nd coolant pump ... meanwhile, things changed just a bit, like they always do / kindly
  1. Replies: 5
    Last Post: 01-27-2018, 03:23 PM
  2. OKK Pallet Check M-Codes
    By CNC Kid in forum OKK
    Last Post: 11-02-2016, 02:25 AM
  3. Replies: 0
    Last Post: 02-17-2014, 06:37 PM
  4. G codes and M codes for Mazak Quick Turn T-2
    By sauli in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-23-2011, 05:22 PM
  5. free software that can convert g codes to heidenhain control...
    By 050177e in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 07-31-2009, 01:27 PM
