586,633 active members*
3,021 visitors online*
    Feb 2019
    Chinese Laser - laser won’t fire
    Hello All,
    Purchased a 60w laser and finding out laser will not fire from pulse button on control panel or when file is loaded. Head will move as if cutting image but laser will not fire. Laser will fire when “test” button pushed on laser power supply. Suggestions?
    Re: Chinese Laser - laser won’t fire
    Quote Originally Posted by BS2011 View Post
    Hello All,
    Why the laser has no laser beam? - Thunder Laser
    here's a lesson, hope it will help. good luck
    www.thunderlaser.com
    Aug 2014
    125
    Hello All,
    The connection between your controller and PSU is faulty. Check the laser connection coming out of your controller.
