586,655 active members*
3,922 visitors online*
    Lightbulb Polycarbonate engraving, what laser?
    Hi folks, thanks in advance for any helpful advice.
    My company wants to produce various event passes and tokens by printing on and engraving polycarbonate. We are looking to go down the laser route for engraving and want to know if it's possible to laser engrave polycarbonate without discoloration.
    If anyone has any knowledge in this area, I would really appreciate hearing from you.
    Many thanks,
    Rob.
    Apr 2004
    5742
    Re: Polycarbonate engraving, what laser?
    No, you shouldn't ever burn polycarbonate; the fumes are quite toxic. It's on the list of materials that are never supposed to go in the laser cutter. Here's a MSDS: http://web.mit.edu/rocketteam/www/us...ycarbonate.pdf There's no problem with printing on it, though. And it engraves well with rotary tools; it's one of the better plastic materials for routing. It doesn't melt or discolor when cut with sharp tools.
    Andrew Werby
    Website
    Thanks for replying. We will avoid polycarbonate cards in this case. Do you happen to know what medium suits laser engraving? Is there perhaps a material that can be engraved and then laminated onto the print?
    Feb 2010
    155
    Acrylic (assuming you are ok with its brittle material properties) is excellent for lasering, both cutting and engraving.
    and also ABS-double color board good for laser processing.
    www.thunderlaser.com
  1. Is anyone laser cutting polycarbonate
    By Psi For Fun in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-30-2022, 08:33 PM
  2. Barcoding on Polycarbonate by DP Laser
    By alokjhas in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-11-2010, 02:13 PM
  3. Laser/Waterjet SS 316 5-8mm (0.27/0.33) and 8mm (0.33) Polycarbonate
    By rugludallur in forum Employment Opportunity
    Last Post: 03-15-2010, 11:51 PM
  4. Sub pixel Laser engraving polycarbonate
    By Aquacut in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-14-2010, 11:56 AM
  5. laser sub-engraving inside polycarbonate - safe?
    By Aquacut in forum Glass, Plastic and Stone
    Last Post: 01-14-2010, 08:56 AM
